Question about Sony VAIO VGC-RB34G PC Desktop
My sony computer keeps powering off & on and will not boot up
  • Sony Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 08, 2013
My acer computer will not boot up it keeps asking for the boot up disk . This is new since it was working fine prior to this
CHECK THE BIOS NB POWER ON AFTER PRESS F2 KEY & ENTER BOOT OPTION & SEE THE HARD DRIVE ,FIRST BOOT DRIVE DVD-RW SECOND BOOT ORDER HDD OPEN DRIVE & INSTALL CD & DVD PRESS F10 NB RESTSRT WILL BE AFTER BOOT ,,,PLEASE TRY.
Mar 02, 2012 | Acer Aspire 5732Z-4855 Notebook
I want to restore my computer to factory settings
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Aug 02, 2011 | IBM USB Portable Diskette Floppy Drive for...
My computer is in power safe mode
if you want to get your computer out of power safe mode
Restart your computer
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
hope this helps
Jul 01, 2011 | Dell (E210882) Motherboard
My friend Sony Vaio Laptop is formatted by a person and also installed windows xp . Now the Laptop has'nt original recovery tool to restore the system to its Factory default... I need the DVDs to for...
Hope this helps
May 20, 2011 | Computers & Internet
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
or
Also you might try
hope this helps
May 01, 2011 | Sony Computers & Internet
How to reset my motherboard - dg35ec intel
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Hope this helps
Apr 26, 2011 | Intel DG35EC Motherboard
How to unlock power safe mode
or
Also you might try
hope this helps
Apr 19, 2011 | Computers & Internet
My grandaughter's Sony VGN-FW140E laptop will not boot up after being turned off unless it is unpluged from adapter, the battery removed, allowed to sit idle for 3 or 4 hours then put the battery back in...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 14, 2010 | Sony VAIO VGN-FW140E/W Laptop
When turning computer on boot start and freeze when screen show F2 F12 . Nothing else work no matter what key I press. It wont even turn off unless we disconnect power supply and remove the battery.
It may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to
the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now,
restart the computer and keep on tapping F2, you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are
prompted), it will restart the computer. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will
loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e
Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 27, 2010 | Acer Aspire One PC Notebook
Sony walkman b135 say boot error after that power
Dec 26, 2009 | Sony Walkman NWZ-B135 MP3 Player
Sony VAIO VGC-RB34G PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
