Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer, model number MAH5500B
Hi: My Maytag Neptune Washer, model number MAH5500B will turn on and go through the wash process, but will not drain properly. I recently put new hot and cold water hoses on the unit. I called a repairman out and the first time he came he told me it was the detergent I was using. It seemed to help for a short few months and started to get worse and I called the repairman out again. He could not give me a clear answer for what the problem was. Please help me to fix the problem. Thanks, William
  • Anonymous Mar 15, 2014
    need model number
  • 164 Answers
Check for a kink in the drain hose. if not remove the front of the machine, remove the the hose that connects to the bottom of the tub and the other end that connects to the pump. feel inside the tub for any obstructions and look into the pump for any obstructions.
Posted on Jul 01, 2007
Neptune error code LR, means what?
Maytag & whirlpool was recall Maytag Neptune MAH5500B.
Oct 16, 2014 | Maytag Neptune MAH5500B Front Load Washer
Washing machine is not spinning properly
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 01, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer wont go through the cycles... it stops working before the final rinse cycle
MAH5500B Maytag Neptune washer stops and I have to put back into star and not just wash one side wet clothes and Susie sige water drains can only hear a buzz and it takes many items and each shaved marked "nf" and "Lf"
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washing machine - wont drain & spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytage Neptune Model #MH5500BWW will not drain
I removed the pump and removed thread from a rug that had been washed the day before. The thread had bound up the pump preventing it from turning. Once the thread was removed and the parts put back together the machine worked perfectly.
Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
884 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
