Question about Bialetti 20-9 Stove Top Espresso Machine
How can I clean the melted rubber seal from a Bialetti Top Espresso Machine?
I scraped off as much melted rubber as possible - using my thumb nail - then used a product called Goo Gone to melt the remaining rubber. I put Goo Gone on an old cloth and rubbed off the remainder of the rubber - again with my thumb nail.
Posted on Mar 13, 2013
  • Lois West Mar 13, 2013
4 Suggested Answers
JohnnyBeans
  • 223 Answers
SOURCE: Bialetti will not make coffee
I would check the grind size you are using. Maybe it is ground too thin and the pressure cannot push through.
Also, remove screen and washer and make sure passage to the top is clear.
Shop Bialetti's Soon on:
www.CeriniCoffee.com
Posted on Nov 20, 2007
SOURCE: My espresso maker, a Bialetti, has its top very stuck to its base
i had the same issue. i ran the base under very hot water from the tap for one minute. This forces the metal to expand and loosen, making unscrewing the base much easier.
Posted on Jun 06, 2009
  • 5603 Answers
SOURCE: how do I best remove
You might try Toluene... use with VENTILATION.
Posted on Feb 09, 2011
I have changed the rubber seal and now I get no coffee!!
check under that plate with holes and make sure water is just under safety valve inside. make sure plate holes are open and the pipe that delivers the coffee
Sep 01, 2013 | Bialetti Moka Express 6-Cup Coffee Maker
I melted the rubber seal in my 4 cup Bialetti coffee maker. I forgot to put the water in it. Now I am trying to remove the smelly melted rubber from inside the threads and and coffee holder. Please how can...
I have the same problem. Scraped most of the rubber off mine with a knife. I'm going to try steel-wool next, as the whole thing is stainless-steel (or perhaps in your case, Aluminium), it should take a good sound beating.
I wonder if there are any solvents that would dissolve the rubber?
Apr 13, 2011 | Bialetti 20-9 Stove Top Espresso Machine
Hello! I change the rubber sealer to my Bialetti 12 cup yesterday and since then the water stays in the bottom and does not rise to the top. The sealer is properly put in. I have not done anything...
This happened to me, too....the gasket needs to be broken in so that it seals properly, which will happen once it's been used several times. In the meantime, just tighten the pot together extra tight and that will help to seal the gasket properly. After several uses, you won't have to tighten it so much and can go back to how you've always done it. I hope this helps!!
May 19, 2010 | Bialetti Moka Express 6-Cup Coffee Maker
I want to change the rubber seal on a bialetti coffee maker
Just take your coffee maker apart and look under the top part. You'll see the seal and the metal filter. They are only held there by the friction of the seal itself (and any crud that might have built up by now). So with your finger nail or a butter knife pull out the seal, and with it will come the metal filter. It's not a bad idea to do this every time you clean your maker anyway. To replace with old or new seal, just put it back in place: first metal filter, then seal. Easy as can be.
Apr 21, 2010 | Bialetti Venus 4 cup stainless steel...
Nov 20, 2007 | Bialetti 8853 Espresso Machine
Bialetti 20-9 Stove Top Espresso Machine Logo
280 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Pennywhistler
Pennywhistler
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
