Question about Pantech Pocket
I still cant put the message center number in my pantech pocket
The step by step solution does not help as i there is no place in the cettings that offers the center number
  • kinggajones
    kinggajones Feb 06, 2013
    Like i said before, my Pantech pocket is missing some settings in the message settings, there is a setting that allows you to put in the centre number of your network provider, mine does not have that setting. Now i am told by a technican that this was done intentionaly by AT&T, and that there are some codes that need to be put into the phone to bring out these settings. Now if anyone out there nows anything about this or has a solution, i would be most greatful as i have been using my for for some time now and cant reply any of my text messages.
How do I delete text messages on pantech P9060 pocket phone
Delete a Single Message
  1. From a Home screen, tap Apps.
  2. Select Message+.
  3. Select a conversation.
  4. Touch and hold a message.
  5. Select Delete Messages.
  6. Select additional messages if desired. Message is selected if a check mark is present.
  7. Tap Delete (located in upper right).
  8. Tap Delete to confirm.
Dec 03, 2016 | Pantech Cell Phones
How do I hard reset my Pantech cell?
you will lose all your data but this site give step by step instructions
Reset Cell Phone How to master reset Pantech Pocket P9060
Jul 17, 2015 | Pantech Cell Phones
Unlock code for p9060 imei 012764000500212 06
Hello, it is possible to use the online service to disable the SIM Locked message on fastgsm.com
Jan 10, 2013 | Cell Phones
I cant send text messages, how do i put the centre number in.
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Jan 04, 2013 | Pantech Pocket
Text messages not going thru
My Dear Brother:
4.note it down
Good luck
Dec 06, 2012 | Pantech Pocket
My pantech laser wont send messages
CHECK YOUR MESSAGE CENTER NUMBER .. IT IS CORRECT OR NOT
Sep 07, 2012 | AT&T Cell Phones
I have a Pantech c810 cell phone my friend gave me and I put my tmobile card in it. It works but the only thing that don't work is I can't send or revieve picture messages!!! :/ Help!?!?!?
the first step is to power off then back on.. the device. if this does not help. you may need to remove the battery while the device is still turned on. wait five seconds before putting the battery back in and restarting the phone.
Jun 12, 2010 | Pantech C810 Pocket PC
Accidentally changed things
You can get the center address from your network operator.
Jun 25, 2009 | Pantech Matrix Cell Phone
MY TEXT MESSAGING WONT LET ME TEXT ANYONE. IT SAYS TEXT MESSAGE FULL BUT I HAVE NO MESSAGES IN MY INBOX OR OUTBOX
Does it show signal bars on the screen and are you able to make/receive calls? If not then that is why. AT&T does not guarantee in building service. If you do have signal and it is working other than text, then check your message center number in the device:
From the standby screen, press Menu.
Press Messaging.
Scroll to and select Settings.
Scroll to and select Text Message.
Enter appropriate Message Center Number, then press Done. The message center number that should be there is +13123149810 (and the + sign does need to be in front of it)
May 31, 2009 | Pantech Slate Cell Phone
Pantech Pocket Logo
20 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
