Question about Winter Sports
1991 ski doo safari l 377 runs bad intill warmed up
Just put new cdi box on before that it would run good till it was warm now just the opissite
emissionwiz
  • 76846 Answers
SOURCE: 1991 chevy lumina will hardly run
DTC - 22 Throttle position sensor error (signal low), is tps connected?
DTC - 23 Intake air temp sensor error (low temp indicated) check and make sure the sensor is connected
DTC - 43 Knock sensor error, ignore this for now, will not cause rich run.
DTC - 53 System voltage too high, check reference voltage from PCM, it should be around 4.5 Volts, this could be the cause of all your problems, the computer will need to replaced almost for sure.
Posted on Oct 06, 2008
  • 10 Answers
SOURCE: my 1991 yamaha fzr 600 wont start
how long did you let it sit for with gas in the carbs, you may have clogged up your jets. after awile gas will break down and turn into varnish, if your bike trys to push the varnish through the system it will clog the jets. try to take off your seat then remove your plastic over the gas tank. remove the gas tank and you will see four bowls *silver ones right next to where the gas tank is on the carbs*. your bowls are in sets of two. there are drain screws on the bowls to remove the gas inside. remove the 16 screws holding the bowl onto the carb. *4 on each* inside you will see your floats and jets. carefully loosen the jets with a screw driver then finish unscrewing them by hand, they are brass and very soft. you should be able to hold up the jets to the light and see a small pin hole. if not get some carb cleaner and give them a squirt and blow them out. do not try to use anything to clean them out, they are very very sensitive and one knick will change the jet. after that i would spray some carb cleaner up the jet holes and try to clean them out also. if you have a compressor it would be wise to use that to blow out the gunk from the jet holes as well. after you run threw all 8 jets put them back together and see how it goes, if nothing you may have to check the jets again and if clogged again your carbs are gunked up and will need to be cleaned
Posted on Aug 12, 2009
dj_relly999
  • 4070 Answers
SOURCE: bad cold starting from my 2.7 diesel
good day, you might want to replace your engine oil with some anti freeze additive, may work just fine. hope this helps, have a nice day
Posted on Feb 08, 2010
  • 114 Answers
SOURCE: runs real rough up to 1500 rpm and dont hardly idle
Change your fuel filter for starters. I'm assuming you keep up with tune ups so plugs and wires wouldn't be the issue. If you haven't changed your PCV valve in a while I woud change it, or at least clean it. That plays with all sorts of systems. And finally, the most irritating one. the EGR valve. They can cause all sorts of problems so the symptoms can be all over the place. Aside from killing your performance, they also confound mechanics by behaving like other problems. Good luck.
Posted on Apr 17, 2010
SOURCE: my 600 xc will run for a short time till its warm
Did you get any good advice i have the same problem on my 1996 indy 500 efi. LET ME KNOW drozek1@live.com
Posted on Feb 13, 2011
Making noise running
Is the check engine light on ?
Have you checked base fuel pressure hot and cold ?
Aug 31, 2014 | 2003 Pontiac Bonneville
Truck runs till warmed then dies
sounds like it is running out of gas
Jul 29, 2014 | 1985 Ford F 250
Runs really bad when engine is warm
Sounds like your engine temp sensor is bad. check wiring for cuts or loose connection.
Apr 22, 2014 | Ski-Doo Expedition SE 1200 4-TEC Winter...
2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
Jul 25, 2012 | New Ray 112 Scale Bombardier Sea-Doo XP...
My 1991 Jeep Cherokee runs great till it warms up, once it warms it seems to sputter and miss
easy way to strat is check all your spark plugs.jeeps are also known for the crank positioning sensors going bad.another possibility is the oxygen sensor
Jan 21, 2011 | 1991 Jeep Cherokee Limited
I have a 1991 Olds cutlass ciera 3.3 v6, starts up fine when cold/cool. Runs down road fine till warm, then stalls, will not restart. Cranks fine, just won't fire up. You can pull air filter, sprinkle...
Good Evening, you might want to check those injectors, I can not remember for certain but that setup was sequential and when one or two have a problem it would take out the rest. Ohm out the injectors and see what you have there.
Nov 03, 2010 | 1991 Oldsmobile Cutlass Ciera
92 virago 750. Front cylinder runs intermittently. Coil is good. I cleaned carbs. Suspect CDI. Seems to run fine until it warms up. I recently put new Voltage Regulator in. Stator is not shorted. and...
You have to test all the electronics on the bike to figure out if you have a bad CDI box. A CDI box can test good and still be bad. Your problem sounds more like a bad spark plug cap. Unscrew the cap from the end of the wire and take an OHM reading on the cap. If it is higher or lower than 5000 OHMs replace the cap . A plug cap from NGK runs about $5. Replace them both for about $10 it should take care of the problem.
Oct 04, 2010 | Yamaha XV 535 Virago DX Motorcycles
Jet ski
too rich, adjust thehigh idle screw
Jul 06, 2008 | 1997 Chevrolet Cavalier
Winter Sports Logo
57 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
