Question about Kodak EasyShare C875 Digital Camera
Will a SDHC 4G card work inthe c875 camera ?
Would like to use a larger capacity SD card in camera..purchaased a 4GB SDHC card and it will not work. Indicates it needs to be formatted. What do I do ?
  • Anonymous Mar 14, 2014
    CAN MANUALLY HOLD SDHC CARD IN, BUT AS SOON AS THE PRESSURE IS RELEAST THE SCREEN INDICATES NO CARD
  • 4 Answers
I don't know if you got my last post (pc playing up,im not going to tell you its the user :))
the answer is no you can only use upto a 2 gig card on this camera
(did a search on the kodak website then phoned them up for you and that's their answere)
Posted on Jan 20, 2009
What memory card can i put in my easyshare c875 kodak
The C875 works with MMC and SD cards. MMC cards are going obsolete, so you'll probably not be able to find many of them. When getting an SD card, make sure it's not an SDHC card. SD cards top out at 2GB while SDHC cards start at 4GB and go up from there. SDHC cards will not work in the C875.
Aug 29, 2011 | Kodak EasyShare C875 Digital Camera
I can't seem to format my C875 easyshare with a 4gb kodak memory card. Help!
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 19, 2011 | Kodak EasyShare C875 Digital Camera
Why my 4GB SDcard can not work at my NIKON coolpix 5900
There are no 4GB SD cards. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 16, 2011 | Nikon Coolpix 5900 Digital Camera
CX7525. Inserted new 4gb sd card. Camera says it needs to be formatted. When I click on the "OK" button to format, it says "card needs to be formatted" again and again. Will not format...
There are no 4GB SD cards. "SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 29, 2010 | Kodak EasyShare CX7525 Digital Camera
4gb card is not recognized
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. A 4GB SD card is actually SDHC.
Nov 27, 2010 | HP Photosmart 812 Digital Camera
Can't format new memory card
Nov 16, 2010 | Kodak EasyShare C875 Digital Camera
My c875 kodK Cmera won't format my 4gb sd card..why
Is it actually a SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 05, 2010 | Kodak EasyShare C875 Digital Camera
Memory card compatibility. camera won't read or
The C875 works with SD and MMC cards, which max out at 2GB. It will not work with larger SDHC cards.
May 14, 2010 | Kodak EasyShare C875 Digital Camera
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it, but it says CHECK SD CARD. I tried another 1GB memory card and it worked. I know that the problem is with my...
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
Mar 23, 2010 | Samsung Digimax D53 Digital Camera
Can I use Standard 4G or 8G SD or Cf cards in a Dell Axim X5?
SD cards must be SD not SDHC, there is not an SDHC driver for the X5. You can find regular SD cards up to 4G.
CF is no problem, all flash based CF cards will work. Microdrives can be problematic.
Dec 20, 2008 | Dell Axim X5 Pocket PC
Kodak EasyShare C875 Digital Camera Logo
701 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
