My lamona washing machine door won't lock - can i get a spare door closer or do I need a new door ?
  • S THOMAS Jan 10, 2013
    help needed urgently !
TheMobilian
  • 8220 Answers
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
Posted on Mar 19, 2010
  • 16 Answers
SOURCE: The door is jammed on my LG Intellowasher
Hi, Has all the water gone out of the machine? Try it on another spin cycle if it opens then the drain filter or pump could be blocked.
Regards Elect App
Posted on Jul 14, 2011
  • 251 Answers
SOURCE: washing machine won't go thru spin cycle. Lid
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Posted on Jul 15, 2011
  • 6277 Answers
SOURCE: Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 27, 2011
  • 360 Answers
SOURCE: My mother accidentally pulled the
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Posted on Aug 07, 2011
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
LG WD1470FD won't open
You will need to replace the door lock assembly. If remove the top, you can reach down and manually open the door. Below is a video to show you how to replace the lock. Here is the lock to order.
Dec 04, 2012 | Washing Machines
J1045iw1/x5sa
Please check for spares from :Spares
Replacing door lock: click on: door lock
Jul 05, 2012 | Samsung Washing Machines
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Lamona HJA8553 Washing Machine door release has suddenly stopped working!! Is there an emergency door release to get my wet washing out??? tried turning off at the wall in hope of resetting the machine...
My Lamona integrated washing machine HJA 8553 has a nasty smell coming from it like an old damp mop its making the whole of the house smell any ideas why
Jun 30, 2011 | Washing Machines
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
Door won't lock..machine won't start
could be a faulty door lock as this is required to be locked before a signal is sent to the controller to start the wash cycle, try replacing the door lock, there quite cheal only a few pound
May 31, 2011 | Kenmore Washing Machines
Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
Jun 08, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
