Question about RCA RTD170 System
Replace remote and cords - RCA RTD170 System
Lost in moving Proscan hdtv Model 15LA12Q power cord and remote where can I replace them? Thx so much for help
These tv use a universal cord which can be picked up for around $4 from any Walmart or Home Depot store.
Mar 13, 2018 | Proscan Televison & Video
Olevia television won't turn on unless you unplug the power cord from the back and plug is back in
One of the buttons has flattened out try the remote first and see if it will pop up, if so replace remote. Then try the one on the TV itself which is more likely...that one will require a new PC board with the buttons on it.
Jul 23, 2014 | Olevia LT42HVi 42 in. LCD Television
I lost the power chord to the remote on my George sound system by Chestnut Hill
unfortunately it seems the George is no longer available. However, the power cord is a USB cord then you should be able to replace it by picking up a multiple USB cord kit (the one that has both the standard and mini sized cords).
May 23, 2014 | Apple Chestnut Hill Sound GEORGE Compact...
I need a charger for 7752v remote
you can charge it from your computer if you have a mini usb cable like one from a camera would work. Also if you have an old cell phone charger that has the mini usb connector on the end will work. The motorola driod x charger would be a perfect match. If you need to replace the battery because the remote will not turn on any more I replace the batteries on ebay search viper 7752 remote battery service. Hopefully this helps.
Feb 05, 2013 | Viper Televison & Video
I have Bose in-ear headphones with remote. I use them during my workouts and I think the sweat has damaged the remote that's on these headphones. The remote has stopped working and it erratically...
Ayish DX,
If you just want to get rid of the remote control functionality, you could simply replace the cord for your headphones. This may be a little difficult to do, but it is possible. Do keep in mind though that you have purchased a Bose product, and unless they have changed lately, they provide a lifetime warranty on almost all of their products. you may be able to send off for a replacement pair! if this is the case, don't make any modifications at all, as you will void the warranty.
~Kudos~
May 03, 2011 | Bose in-ear headphones - Black with...
We have a dell monitor/tv and the remote control wouldn't work all of a sudden. when we tried to fix the problem, somehow we "locked the buttons" and cannot figure out how to unlock it.
Email Dell tech. support with your issue.
But first try removing the power cord and press and hold the power button on the front face of the unit for 30 seconds..
Remove the battery on the remote and press any key on the remote for a few seconds.
Replace the batterys on the remote and power cord on the Monitor.
Try to power up the unit and see if that works.
The Monitor/TV have a CMOS battery which retains all your setup information. By removing the power and holding the power button, you may be able to clear the memory and reset the unit.
Sep 06, 2009 | Dell Computers & Internet
My remote wont turn on A.C. and when I push manual override cool or heat nothing happens the unit is a coleman mach with the RVP remote I am also getting the led flash on 2 seconds off one,my remote test...
If the system does not turn on and there is not beep, it is either a low or overvoltage situation or a problem in the wiring. Check the 12VDC at thermostat and make sure that it is OK. Also, check the incoming 120VAC at the control box (unit with small phone cord)
Jul 06, 2009 | Coleman Mach III Air Conditioner
Human touch HTT 800 just beeping from back, not remote
Just had this problem with our HTT 800. Discovered it was the curled phone-like cord attached to the remote that had been chewed through by one of our dogs. Some electric tape fixed it right up. Still looking for a replacement. Anyone know where I can find one? A standard-size phone cord does not work with this, as it is too large.
Feb 27, 2009 | Interactive Health Ht 135 Massage Chair
5 Key in-cord remote control for for Philips GoGearKey 019
How does the 5 key in cord remote control work for the philips key 019 do not have a manuel
Nov 02, 2007 | Philips GoGear KEY019/17 Digital Camera
RCA RTD170 System Logo
15 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
