Question about Xerox Office Equipment & Supplies
Xerox dc250 error code 077-130
I think its the duplex sensor, but i want to know how to sort it out
2 Suggested Answers
  • 2072 Answers
SOURCE: Xerox DC250 error code 093
either you are out of black toner, or the toner dispenser needs serviced. It is not seeing the proper amount of black ink.
Posted on Apr 23, 2008
Xerox DC250 Fiery error '8d' on small digital screen
I Just check the service manual for it looks like you have a faulty motherboard the suggestions are as follow.
Faulty motherboard 1. Power off/on the copier.
2. Check again all cables and connections.
3. Replace the motherboard.
LED diagnostic codes (on Fiery LED display)
Any of the following:
CF
C0
C5
01
03
05
0E
10
12
14
16
1B
1D
24
26
27
29
2B
2D
35
37
39
3C
3E
40
43
53
57
59
5D
60
67
6B
6D
77
7F
82
83
84
85
89
8D
94
96
Jun 14, 2016 | Xerox Office Equipment & Supplies
Why does xerox work center 5020 copy only and yet the duplex is okay
Hi Wandekera,
I think you have a operator error problem. If the duplex is working then there is no mechnical problem have you got 2 sheets to copy then you should still have something on both sides of the paper.
Further investigation would be necessary.
Good Luck.
May 04, 2015 | Xerox Office Equipment & Supplies
Xerox DC250 error code 116 340
my machine is the xerox 7245
erros is the 116-340
Nov 03, 2012 | Xerox DocuPrint 340A Laser Printer
Error code 008-900
This error does not indicate a specific sensor. Need to check all the paper path sensors (TRAY 1,3,4, registration sensor, the sensor duplex sensor transfer roller 2, the sensor fusing)
HOpe this helps.
Oct 16, 2012 | Xerox WorkCentre 7328 7335 7345 7346...
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Toner drum chip reset for xerox docucolor 250
dc250 crum reset solution done yes B Patel mumbai 09029222006
Jul 21, 2008 | Office Equipment & Supplies
Xerox DC250 error code 093 317
Apr 23, 2008 | Office Equipment & Supplies
178 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
