Question about Vestax Cdx05 Table Top CD Player CD Player
Error 13 It say no disc when disc is in
The DVD player reads disc error with every disc, even if the discs are cleaned.
If the DVD player is displaying disc error with all the discs, most probably it is a service issue..
Please use a cleaning disc and check if that helps.
Jan 16, 2011 | Emerson EWC13D4 13 in. TV/DVD Combo
C:13:02
After having formatted the memory stick with the cardreader on my laptop which runs on winxp I tried to use the stick in my sony dsc-p5 but all I got was the C:13:01 error message. So I tried to format it again but eith FAT instead of FAT32 which is the regular format on winxp. Now the disc adapter which I use on my desctop to read the memory sticks worked again with the stickt, my camara still gave me the message of not being able to read the stick so I removed the stick, got into the setup mode, reinserted the stick and formatted it with the camara. This worked, I hope this can help you.
May 09, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Mavica mvc-300 disc error c:13:01
I have had similar problem and i think it's a problem with the disc. Make sure the disk is clean and unscratched. Check your other discs, too, to see if they are giving you the same problem. If not, it' is most likely the disc and not the camera.
Jul 17, 2009 | Sony Mavica MVC-CD500 Digital Camera
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
C 13:02 dvd-rw mini disc errors
It's not recommended to format a disc in the Computer and use it in the Camcorder.
It seems that there is an issue with the disc.
The disc should be formatted within the Camcorder itself.
I will forward a link to a page where you can get the information regarding the error message appearing on the LCD screen of the Camcorder.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466
May 15, 2009 | Sony Cameras
Camera dropped, disc error c:13:01 shows up on the screen
Mo- Fixing will cost lots. As for downloading images- go to www.konvar.com and download PCInpector install it and see if it can see your missing images.
Apr 02, 2007 | Sony Mavica MVC-CD500 Digital Camera
Vestax Cdx05 Table Top CD Player CD Player Logo
26 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
