Question about Apple MacBookPro 15-inch 2.16GHz 120GB Laptop (Refurbished) (B002FAM2W2) Mac Notebook
My macbook pro 15" 2010 restarts unexpectedly
My macbook pro screen will go black and then the computer will restart. A screen pops up saying "your computer has restarted for some unknown reason" then asks if I want to reopen all of the programs I had open. No information gets lost, but this is a newly refurbished computer that I bought from Gainsaver and should be working properly
  • Apple Master
  • 3,320 Answers
If under warranty get it replaced.
Posted on Mar 08, 2014
Clearercape
  • 38 Answers
SOURCE: MacBook Screen Problem
Hi there
If I understand you correctly from start up the screen is dim but does brighten up after time? But now after start up you are getting a flicker how ever a restart solves this.
On the dimming issue. Check your energy saving settings and brightness key is working OK.
The flickering is a bit of a concern.
Just a couple of questions.
Are there any dead spots on the screen? Areas where there are no pixels.
When you tilt the screen forward and backward, does this effect the brightness or flickering?
Paul
Posted on Sep 04, 2008
  • 53 Answers
SOURCE: macbook was manually shut down during an update
while starting, hit cmd v. this will put it into verbose mode and show the background processes and where it stops, there will be your problem. Also try inserting an OS disk and hitting c during startup chime and use the disk utility to fix the permissions.
Posted on Jun 04, 2009
damien729
  • 221 Answers
SOURCE: problem with strating macbook pro (screaming voice)
Hello, this certainly has to deal with your RAM memory. have you installed RAM recently? if not, you can try memtest to test your memory, or take our 1 memory after another, Hope this helps
Posted on Jun 11, 2009
kklare
  • 85 Answers
SOURCE: When I start up my MacBook Pro the display colors
It is likely that some program has grabbed (allocated) a good part of the color table. This used to be a problem with 256-color color tables--be sure you are set to millions of colors--Windows could be changing this. Try starting up with the shift key down (safe boot) and if this works, you will need to turn off some program that are being started up automatically. You may need to go to Terminal and look for the resource file ".bashrc" or ".cshrc" (pronounced sea-shark), which could be starting other programs, although I didn't find one on my machine just now. Use the "ls -a" command to list all including the hidden ones beginning with period. I use non-hidden files when I invoke certain Unix programs, just use ". program-name" in the bash shell, with no quotes, of course.
-Ken -Ken
Posted on Aug 17, 2009
MacAppleTech
  • 206 Answers
SOURCE: my powerbook g4 is not starting. it opens the
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Powerbook G4 to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Powerbook G4 and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
At times this procedure does help for gray screen issues so give this a try and let me know if this helps.
Thanks!
-Mactechtrainer
Posted on Jan 26, 2010
Testimonial: "you are my savior! the computer turned on but once i got i on all the desktop icons where working. should i still empty the trash and restart?"
I had to factory reset my tablet and after it factory reset it shut off and when it turned on again it said 'the computer restarted unexpectedly or encountered an unexpected error.
Help laptop wont start after resetting factory settings - Acer ...
www.tomsguide.com/.../77186-35-help-laptop-wont-start-resetting-facto...
Mar 25, 2012 - 5 posts - ‎2 authors
i restored my laptop back to factory settings as it kept crashing, now when i ... TVs · Cameras · Smartphones · Tablets · Software · 3D Printing; More ... or encountered an unexpected error, windows installation cannot ... then restart the installation... i do this and its just repeating itself, i have no recovery discs.
"The Computer Restarted unexpectedly or encountered an ...
heresjaken.com/the-computer-restarted-unexpectedly-or-encountered-an...
Feb 1, 2013 - Now your computer will restart and continue on the Windows setup process ... THOUGHT MY 1000 DOLLARS COMPUTER HAD CHRASHED AND .....setup experienced an unexpected error" To install windows, restart the installation. .....JUST fyi - I had a similair problem on a Surface Pro 3 tablet and this ...
encountered unexpected error when going to factory reset ...
h30434.www3.hp.com > Laptop & Notebook > OS/Recovery
Jan 13, 2016 | Computers & Internet
First time start up error message
indicates a problem hard drive not allowing the boot up to complete
take it to a computer repair shop for a proper diagnosis
Apr 24, 2017 | Fujitsu LifeBook AH531
Serato does not acknowledge that my NS7FX is plugged in. All the crds are connected correctly, since I was using it perfectly this morning. At the bottom of the Serato screen it says "Hardware...
The first thing to try is a safe boot. Unplug the NS7FX from your computer and restart it again. This time, when you see the computer screen go black, hold down the shift key until you see the spinning gear displayed beneath the grey Apple logo OR until you see a progress bar. Once you see either of those, you can release the shift key. This boots your computer in Safe Mode which clears caches and does a disk check. It will take a while for this to complete, so please be patient.
When you see the login window you should also see Safe Boot in red about the list of accounts. At the bottom of the Login Window, you should also see Restart, Shut Down and Sleep buttons. Plug in your Numark NS7FX and the restart the computer again.
Login normally and see if the device is now recognized.
Let me know if this fixes your issue.
Ken Harris
Feb 28, 2011 | Numark NS7FX for PC Mac (676762186612)
Brand new laptop and when switched on for the first time message pops up during setup. It says 'the computer restarted unexpectedly or encounted error. Windows installation cannot proceed. To install...
try reseating memory modules, see if nay change, if no, then try the modules individually, one may be bad.
Try running system in safe mode (F8 at boot) see if it will get past issue
Dec 25, 2010 | Computers & Internet
How do you restart the macbook pro from a grey screen with the power button icon on the background? All it says ''you need to restart your pc hold down the power button until it turns off then press the...
You probably need an OS-Reinstall. Take it to the apple store and see if they'll do it for you. If they don't there are third party Macbook Repair services that can fix it for you. There are also free Macbook Repair guide that show you how to restore it yourself. You should still have your install CDs to do the restore.
Jul 08, 2010 | Apple Customized 15" MacBook Pro Laptop...
Problem with strating macbook pro (screaming voice)
Jun 11, 2009 | Apple MacBook Pro Notebook
Macbook Pro goes from gray apple screen to black
Try booting into single user mode by pressing Command+S while booting. You should then be at a prompt. Type in:
fsck -f
and press Return. Let it run and see if it corrects any filesystem issues, then reboot when it's done.
Apr 25, 2009 | Apple MacBook Pro PC Notebook
Apple MacBookPro 15-inch 2.16GHz 120GB Laptop (Refurbished) (B002FAM2W2) Mac Notebook Logo
264 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
