Question about Cooper Wiring Devices ACE6003W-K ACE" 3-WAY ROTARY PUSH DIMMER
I have just changed a two gang switch that controls the bathroom and landing light but now the lights in the bathroom and landing wont work all the other lights work and no fuse has tripped
I changed an old brass switch for a new plastic one and changed it wire for wire may of caught a nuetral with screw driver when changing
  • 3,287 Answers
That could be the culprit - right there.
You see, the new dimmers work electronically. There are no moving parts really. Voltages are changed in some very high tech ways thru transistors and triacs. These are comparatively "delicate" devices to the old snap switch and rotary dimmers that had large moving pieces that could handle a large load (like your short via the screw driver) for a short time. Not so with a transistor or triac however. There are so small, they have no way to dissipate heat like the other switches and *instantly* fail. The amount of current in amps needed to blow the transistor or triac is much lower than that needed to blow a fuse or circuit breaker - so that's why it never opened. That is why the instructions often call for removing power at the panel before installing.
So, unless it is a simple wiring error, my money is on a blown dimmer switch. Double check you work and try again with the power OFF.
Posted on Jan 16, 2013
2 Suggested Answers
goldenglove1
  • 144 Answers
SOURCE: have a 2 gang 2 way switch,one of the lights
I think your goal with the 2 way switch is to be able to turn the landing light on/off from either the top of the steps or the bottom of the steps. When you run a one way light in with that circuit it will not make a complete circuit, hence the 2 way will not work. If your bathroom switch was in with the light switch at the top of the steps, you will have to seperate these two switches. Make the bathroom a switch by itself, and then connect the two way switches. If a circuit is not making a loop it will not work. 2 ways must make an uninterrupted loop, (the one way is interrupting the loop) in order to function properly. Hope this helps!!!
Posted on Sep 21, 2010
I replaced a two gang light switch and now only the bathroom light works landing no help
Assuming both switches are single pole...
One black wire from connects breaker connects to each switch.
One black wire from light goes to light
http://waterheatertimer.org/How-to-wire-switches.html#gang
If your switches are 3-way... then re-post new question.
Gene
Water Heater Timers Save Money
Mar 14, 2015 | Electrical Supplies
Got three seperate lights want to put in into one thee gang light switch
Copy following link for wiring 3-gang switch:
Nov 19, 2011 | Home
The bathroom light does not turn on, I changed the switch but now the light in the hallway does not turn on. The original switch was wired through the back but I have changed it to the side.
Is the bathroom light controlled by two switches?
Is the hallway light controlled by two switches?
What color wires are in the bathroom light switch that you changed?
Side wiring will not change the way the switch works.
Dec 12, 2010 | Leviton White 3-way Toggle Switch 15a...
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
Have a pull switch with three terminals marked 1 gang 2 gang and com need to wire a light, which colour wire goes where
It sounds like you have a pull chain switch that turns on one and/or multiple lightsor light and fan. The common wire would be a colored wire (probably black or red) and the one and two gang terminals would be your switch connectors. Neither terminal should be connected to a white or green wire..
I hope this helps out.
Oct 01, 2010 | Home
Have a 2 gang 2 way switch,one of the lights controlled by this switch is really only one way,the other(landing)light is 2 way.I can not get the 2 way to operate correctly they control a bathroom light...
Sep 21, 2010 | Cooper Wiring Devices ACE6003W-K ACE"...
I need to wire a 3 gang switches in a 3 gang box
before u start make sure power is off before working with electrical lines ---start with the 12/2 coming into box black [power] white [ground-neutral] and u will have 3 separate lines for the lights so u will have 4 lines total coming in the box== with the 3 light lines take the white and strip back the plastic and connect [wire nut] all 3 to the 12/2 white line --now take the 12/2 black line and connect it to the first switch gold color screw- bottom screw -now take some wire about 2-3 inch strip both ends and connect from the 12/2 black wire connection on the switch and connect to the gold /bottom of switch 2 than do the same for switch 3 connecting the wire from switch 2 so u will have power feeding all 3 switches-- now connect the black lines for the lights to the other side of each switch and ur done
Feb 14, 2010 | Cooper Industries Cooper Wiring 2158V 3...
We want to replace our bathroom exhaust fan. We like the Harbor Breeze 'Rosemont' model at Lowes. It's a decorative combo fan/light unit. The unit is equipped with 2 13 watt (60 Watt incandesant...
It does not matter whether you turn on the switch or the switch is motion
activated, the light does not know who turns it on.
The switch must be designed for florescent.
What do you mean by proper base, you have a single gang wall box,
that's a box inside the wall, with the electric and a switch,
The gang could be single or hold 5 switches, which ever is installed.
Most all switches fill fit into any gang box.
Feb 08, 2010 | Dryers
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
Cooper Wiring Devices ACE6003W-K ACE" 3-WAY ROTARY PUSH DIMMER Logo
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
