Question about Mitac Mio P550 GPS Receiver
Mio p550 i have jusr finnished downloading and the unit tolf me i am out of basic memory, although i made sure to download it into my 2gb extra card i have tried to delete programs but the list was never filled up so i had no program list to delet rom. now to unit will not start up beyond the page which shows the greenie map can anyone help to restor it to its glory? i have tried the reset botton and the off/on switch.....nada
  • guy wose Jul 01, 2007
    you advertise yourself as free service and then after hooking the customer details, you are demanding money for the service.....
    good luck to you......... i aint NO moron
    maybe with others you will have better luck
    hi there again
    now after getting the mio p550 working again
    i am not able to sinc it (the short cut for the sinc does not appear on my desktop)
    and thus it says that sinc could not work and i should look up at m/s help for a solution
    i did try to remove the program and reinsall it but no short cut
    any ideas?
    thanks
    guy
Thank you but i have mannaged to get it going by pushing the joystick uo and pressing the soft' at the same time that brought me to the factory settings so now i have to reload mio maps and all the rest of the data that was lost thank you agian for your help
Posted on Jul 01, 2007
    Scholar:
  • 74 Answers
I dont know about the charges but did you "format" the card?
SOURCE:
I have a Mio P550 with Tom tom 6 installed, when I try to run Tom Tom all I keep getting is no valid GPS
Hi Dave,
First off, go to your GPS settings. Make the GPR Program Port: COM4. In the Hardware tab, make the GPS Hardware Port COM2 and the Baud Rate 4800. In Access, have the Manage GPS Automatically checked.
Download the VisualGPSce freeware program from this site install and run it. Make sure you're outside (sorry), you should see the to bars filling and after a while the red light in the bottom corner will turn green meaning you have a lock.
Hopefully now when you turn TomTom on, you will have your position shown. I always need to start VisualGPSce before kciking TomTom off.
Jul 07, 2010 | Mitac Mio P550 GPS Receiver
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Feb 18, 2010 | Mitac Mio P550 GPS Receiver
Can't put Mio P560 in bootloader mode
up arrow + power_on until MIO logo
Feb 07, 2010 | Mitac Mio P550 Pocket PC
How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from www.microsoft.com and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
Aug 08, 2009 | Mitac Mio P550 Pocket PC
Mio p550 not recocnized sd cards
Try this : Open your device ( it have 5 screws). Inside next to the sd card reader are two metallic sponges. Take them off ( they are glued on some electronic parts and it's shorting the circuits)
Mar 13, 2009 | Mitac Mio P550 GPS Receiver
Mio p550 wireless N security connectivity problem
Had the same issue with my Mio P550's using an Airlink680W Wireless N Router and security mode WPA-PSK, TKIP & Password. I had to disable "Block WAN Ping" on the firewall and life is good.
BSL
Oct 03, 2008 | Mitac Mio P550 GPS Receiver
Mio c220s canadian version
I would thnik you could download the US maps from a US cd that came with their unit to an SD card.
The C220 for the US comes with 4 states on the GPS and the rest on an SD card that is in the side of the unit
I downloaded the 46 maps form my cd to a 1GB SD card that I put in a sot on my computer.
http://service.mio-tech.com/M0100/MainFrame.aspx
Oct 02, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 reboots but does not take any touchscreen inputs
I had the same and contacted MIO (use the phone number for your country,
http://www.mio-tech.be/EN/support/support-overview.php
). It was related to the shock the screen got and they graciously changed it for me (it was during the second year of the warranty). If the warranty has expired, you are probably looking to about a hundred bucks expense.
Courage,
Jul 02, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 how do i do a hard reset
on/off switch in "off" position for at least 30 seconds, then turn it in "on " position, power on and "reset". You'll lose all your data and all the installed programs.
Alternative: using the screen options, go to "system info", and choose "hard reset".
Beware: pushing the joystick down while doing a reset will get you a boot menu with memory-formatting options. Choose "exit".
Otherwise look into xdadevelopers forum (Google it or go to, say,
Mio P550 / P350 ROM upload [Archive] - xda-developers
A good idea would be to backup your data in the first place- just a hint.
Enjoy.
Dec 09, 2007 | Mitac Mio P550 GPS Receiver
Mitac Mio  P550 GPS Receiver Logo
402 people viewed this question
Top Mitac GPS Experts
gerry bissi
Ekse
Marvin
Marvin
Are you a Mitac GPS Expert? Answer questions, earn points and help others
