I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
I have a Rheem Criterion II Gas Furnace that will start up and ignite and then after 5 seconds will cycle down. It will do this three times and then turn off, never producing any heat. I turned off the power and cleaned the flame sensor (L shaped bar on first of four burners). Nothing changed. Any additional cleaning suggestions or suggested replacement parts? Thanks!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 83 Answers
You should have a diagnostic flash code to read that will tell you which avenue to explore. look at the bottom panel there will be a sight glass look in and count the flashes a legend in on the back side of the blower door.
Posted on Nov 23, 2014
  • Heating & Co... Master
  • 2,597 Answers
Check air filter is clean , jump out pressure switch see if it lights
Posted on Jan 09, 2013
2 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Have a rheem criterion II. Model
The way it lights is that the gas is spread from one burner to the next by either a flame tray or small holes drilled in the burner tubes. If the flame does not get all the way across the burner tubes within a few seconds, the unit goes out on failure. Clean and inspect each burner tube, not just the orifice. Clean any tray that connects the burners. You can use a small wire brush or tooth brush but be careful near the glow igniter as it is very fragile.
Posted on Dec 12, 2009
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
I have a Rheem Criterion II gas furnace. I have been looking for the filter. Where is It?
Whatever side the cold air return stack enters into the blower unit of the furnace.
Mar 02, 2015 | Heating & Cooling
If it is @ the furnace, then it is in the blower compartment on the return side.
Dec 07, 2013 | Water Heaters
I have a Rheem Criterion II Gas Furnace that has been acting up the last couple of days. It is model #RGPH-12EARJR. It will cycle on, ignite the pilot, 4 burners light and stay lit from 5-10 seconds then...
Turn off the power to furnace.
on the last burner to light there is a small metal rod in front of the burner. This is a safety called the flame sensor. It is dirty. Unscrew it from the bar ( 1 Screw) unplug the connector wire from it and clean it with steel wool. it will be kind of burnt. Plut back in place and turn on the furnace to cycle.
Apr 04, 2010 | Heating & Cooling
Dec 12, 2009 | Heating & Cooling
RHEEM CRITERION II FLAME LIGHT DOES NOT COME ON
1/ overheat stat 2/ fan 3/ diaphrapm valve 4/micro switch when checking fan be sure to check the very small rubberor nylon hose for pinhole best of luck
Oct 29, 2009 | Rheem Paloma PH-20R IFSN / RTG-53PVN...
Heating & Cooling Logo
845 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
