Question about Exercise & Fitness
Nordictrak T5.7 treadmill squeaks while walking
I've tried adjusting tension. Loud squeaking near front of the belt while walking at any speed.
  • Linda Thomas Jan 13, 2013
    Thank-You for the help. Although the cover/console was difficult to remove we managed to lube the bearings and belt. This Nordictrak T5.7 is brand new and I'm wondering if no treadmill is better than a low-end model. At any rate, thank-you for your help. I will continue to watch this site in order to learn more.
    Top Expert:
  • 12,223 Answers
Please LUBE the deck belt and roller bearing very important
if the problem persist after you did. Is time to change the deck belt.
God bless you
Posted on Jan 08, 2013
erpaalai
  • 999 Answers
SOURCE: Squeaking noise on my Proform 580 Cross walk
it is the edge of the belt on the deck. Walk in the middle. Eric
Posted on Aug 11, 2009
SOURCE: I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Posted on Dec 30, 2009
  • 218 Answers
SOURCE: Horizon treadmill loud squeaking sound
you need to lubricate the pivot points and deck. Check to make sure the deck is not broken.
Posted on Aug 11, 2010
  • 218 Answers
SOURCE: belt skips when weight goes on. It squeaks and
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Posted on Aug 14, 2010
guru_fixya
  • 944 Answers
SOURCE: My Reebok RX 5000 treadmill
Open the treadmill case and Just spray WD-40 oil on the belt joints and Just oil the shaft and roller area.Sometimes when belt slips it is designed to shut off to prevent further damage.If still the problem persist then,
Check the safety key
Check the house breaker and the outlet.
Check the 15 amp breaker on the treadmill (if equipped). a. If the breaker has tripped, let the treadmill sit for 15 minutes then power back up. If it trips again but in a shorter amount of time, you have a belt/deck friction problem.
b. If the breaker has tripped but tripped on power up, check for a short-to-ground condition in the electrical parts of the treadmill.
Check all the wiring connections. A loose or corroded wire can cause a brief loss of power that will not result in an error code.
Check the membrane switches. If there is a stuck switch, especially the power switch, it can cause this condition.
Check for an overheating motor. There is a thermal switch in the motor if the motor has blue wires. This can be due to a faulty motor or high belt/deck friction problems. Check for charring in the motor wiring, wiring connectors, or a burning smell.
Check for an overheating console. The console does not run on high voltage so if it is overheating you need to replace the PCB.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 06, 2011
How do I lubricate the c 1800s nordictrack
the only lubrication that needs done is between the walking belt and the deck. if a roller is squeaking either front or rear you can try using wd40 on the bearings on either side
Oct 21, 2014 | Nordic Track Nordictrack C 1800s Treadmill...
I have a Pro-From Crosstrainer xp 580s, walking on the belt isn't smooth and it makes a squeeking noise
You need to adjust the roller tension, The adjustments are at the sides of the treadmill by the rear roller. Sometimes there is a cover over them.
Mar 10, 2012 | Proform XP 580 Trainer Treadmill
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
Squeaking noise from tread
usually when a treadmill begins to make a squeaking sound it means that the belt needs to be lubricated. Try Treadmill Belt Lubricant available at Canadian Tire for $10.99 and is good for Reebok treadmills.
Aug 06, 2010 | Reebok Exercise & Fitness
Belt skips when weight goes on. It squeaks and
Jul 22, 2010 | Proform Exercise & Fitness
Belt squeaking and hesitating when I run
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust. Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts. Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5. Step 4- If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5. Step 5- If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced. Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position
Jun 02, 2010 | Proform Exercise & Fitness
We have an L7 or L8 treadmill. About 2 years old.
Unplug unit remove motor shroud then plug in unit hit start it and listen to where the sound is originating could be the drive belt or if you are walking on it then it could be the running deck post needs to be lubricated
Apr 16, 2010 | Exercise & Fitness
Aug 04, 2009 | Exercise & Fitness
Exercise & Fitness Logo
345 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
