Question about HP Pavilion Computers & Internet
El BIOS no me trabaja y el disco duro no me trabaja
    Sergeant:
    Champion:
  • HP Expert
  • 427 Answers
Be more specific. english please
Posted on Apr 17, 2013
ginko
  • 19396 Answers
SOURCE: al encenderlo lo unico ue funciona es el
Asi parece un problema de placa base.
Para empezar quite la bateria y deconecte el adaptador para resetear la ordenadora.
Intenta remover disco duro, el unidad CD , la bateria, y si el ordenador tiene dos modulos de RAM quite un modulo y intente arrancar el portatil con esta configuracion minima de perifericos, con el adaptador enchufado.
Si el laptop no aranca asi, usted probabilmente tiene un problema de placa base.
Posted on Aug 14, 2009
  • 11 Answers
SOURCE: se formateo sony vaio vgn-cs215 y se instalo win
I Understand, but My portuguese is not up to answer in that language, so translate this.
Formatting the hdd wiped out your restore partition, the only way out is to contact Sony and order a restore disc. it will cost money, but you can order a vista restore CD.
It is the only way.
Posted on Dec 08, 2009
southexpert
  • 69 Answers
SOURCE: A CABO DE COMPRAR UNA ACER ONE MINI. PRENDE LA
puede hacer la bateria que esta baja, tratar de cargarla primero sacale la batteria luego poner sela y cargar y prenderla de nuevo haver si funciona
Posted on Feb 19, 2011
walesarumi
  • 6993 Answers
SOURCE: ESTABA BORRANDO ARCHIVOS CON EL LIBERADOR DE DISCO
Could you please rephrase this question in English? I would love to help you out but I don't understand your language.
I look forward to your reply......
Bye for now.
Posted on Feb 22, 2011
bronk50
  • 27725 Answers
SOURCE: mi laptop no enciende, solo las luces yel disco duro trata de arancar per cero pantalla
google translate
My
laptop will not start, only the lights andthe crank or start hard drive is zero per pantallaenciede lights but the screen is hard not crank or
start
, the fan turns on, heat near the fan, try turning it on without battery and no hard and without ram but not there results
answer
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Posted on Jul 15, 2012
Compaq com ergo
DEBES HACER UNA COPIA DE RESPALDO DE TODA TU INFORMACION LO MAS PRONTO POSIBLE.
TU COMPUTADORA TIENE UNA APLICACION QUE CONSTANTEMENTE MONITOREA EL FUNCIONAMIENTO DE TU DISCO DURO.
AL DETECTAR VALORES QUE ESTAN FUERA DE LO NORMAL, TE ENVIA ESTE MENSAJE PARA QUE GUARDES TU INFORMACION ANTES QUE EL DISCO DURO DEJE DE FUNCIONAR
ESPERO QUE ESTO TE AYUDE.
May 01, 2013 | Compaq Presario Cq11020 AllInOne Desktop...
Compre una imac m6498 pero cuando la prendes aparese una carpetita con una carita seguida de otra con un signo de interrogacion que puedo aser para que funcione
Normalmente el simbolo que mensionas sale caundo el sistema no purde encontrar el disco duro. Pera verificar si es el disco duro que esta fallando o no, completamente apages la computadora. Oprime el boton de poder e imediatamente oprime el boton "Option" y mantenga la tecla selecionada. Esto le senala al sistema que quieres ver todas las seleciones para butiar. El sistema debe mostrar un imagen del disco duro si no esta fallado. Si lo ensena, puedes selecionar el disco duro con el mouse o usando las teclas de direciony oprimes el buton "Return" or "Enter".
Si ningun imagen aparece o mas importante, si no muestra el imagen del disco duro, eso indica que el disco duro ha fallado y necesesitara re-emplaso. El sistem de OS X necesitara ser re-instalado con todos sus aplicaciones tambien.
Jul 18, 2011 | Apple iMac G4 Desktop
Hola, tengo un tv modelo tx-L42D25E y no consigo grabar en un disco duro el disco duro es de 500 G. marca conceptronic. lo he intentado todo.
Tienes que ir a menu, gestion de disco duro (HDD) y all? preparar el disco duro para ser usado con el televisor. El televisor no puede grabar en ningun dispositivo usb que no se haya registrado desde ese menu.
¡A ver si hay suerte!
Apr 08, 2011 | Panasonic Televison & Video
No me deja conectar mas de un disco duro, cuando conecto el segundo me deja de reconocer uno de los dos, estos discos duros son ide
cada unidad de disco duro debe tener un ... ¿c?mo se dice "pin"? alfiler? El pasadordebe estar en "CS" de selecci?n de cable. Despu?s de que el pasador est? en su lugar, conecte un disco duro para el primer conector del cable a continuaci?n,conecte el segundo a la segunda.
Mar 29, 2011 | ASUS Computers & Internet
No puedo instalar Small Business Server 2000 en mi servidor HP Proliant DL360 G3, el software no reconoce los discos duros del servidor. Que tengo que hacer para que me reconosca los discos duros?
Si el sistema operativo no reconoce tus disco, y ya has creado un arreglo nivel 1 o 5 y en la bios si puedes ver los dicos, el problema es posiblemente que necesites cargar los drivers de la controladora. Si puedes ver el modelo de la controladora (visible en el post) dirigete a la pagina de hp.com/support escoje el pais USA para que tengas acceso a todos los drivers, descargate el ultimo driver de tu controladora y cuando este instalando windows presiona f6 para cargar los drivers
Aug 29, 2010 | HP Compaq ProLiant DL360 G3 Server
Muchas gracias mi problemas es que mi presario 700 no reconoce ningun disco duro y ya hsta le he cambiado la tarjeta done va el disco duro montado que puedo hacer, no se apresia ninguna anomalia en la...
Pon tu disco de instalación de Windows en la unidad y reinicie el equipo. Al arrancar, presiona F2 (o F12) y establecer la secuencia de arranque para "arrancar desde el CD" Instalar Windows programa detectará el disco duro e instalar el sistema operativo en ella. Si no lo hace, el disco duro ha fallado.
Mar 29, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Tengo una Nueva Acer Veriton M460 core 2 duo, vista bussines,Disco Duro Seagate 320GB, se hizo downgrade a Win XP PRO, no funciono, volvi a recuperar disco duro, hize lo mismo y no funciono, instale el...
La instalación del HP Compaq no funciona en la máquina nueva porque el sistema (hardware) es completamente diferente.
La mejor manera de hacer el "downgrade" es instalar el sistema operativo desde el comienzo, borrando cualquier partición que exista, donde está el sistema operativo instalado que no funciona. Para eso se necesita el CD o DVD con Windows XP SP2. Esto se hace activando la opción en el BIOS de la PC para que lea el CD o DVD antes que el disco duro. Una vez dentro del programa de instalación, hay que descartar la instalación anterior borrando la partición y volviendo a crearla, usando los íconos del programa.
¡Buena suerte!
Dec 01, 2009 | Acer Veriton M460 Micro Tower Core 2 DUO...
Si desconecto el HD y la unidad de DVD puedo entrar al BIOS pero al conecetarlos no aparece nada en pantalla, el disco duro y el DVD tienen los jumpers correctamente colocados, el cable IDE también...
Resultó ser que estaba dañada la memoria RAM, posteriormente intenté reinstalar el SO Win XP y me marcaba error de lectura, asi que probé con otro disco duro y logré instalarlo sin problemas, señal de que el disco se dañó tambien, antes de sustituirlo probé restaurar el SO con un disco de instalación de Win XP en la opción de reparar y lo intenté con los comandos FIXMBR y FIXBOOT pero no resolvió nada, por tal motivo decidí sustituir el disco duro, ya instalé software y drivers y todo funciona a la perfección..
Espero esto le sea útil a otros usuarios con problemas similares..
SaLu2
Omar Chimés
Sep 29, 2009 | Biostar K8M800 Micro AM2 Motherboard
Disco duro serial ata
Hola VooDooNOFX
Gracias por la ayuda
No estoy configurando los dos discos duros apartes ni haciendo raid a los dos juntos.
El D.D. de 80 gb IDE ya esta parcicionado y formateado (40 c/u, FAT32), tiene windows xp sp3. Uso teclado PS2.
En el D.D. 250 gb serial ata quiero particionarlo en cuatro partes e instalar windows vista, las otras tres particiones para datos.
Voy a hacer esto: Desconecto el D.D. 80 gb IDE y dejo solo instalado el D.D. serial ata de 250 gb para partionarlo y formatearlo con windows vista; primero sin desactivar la función de raid en la bios y luego desactivandola; que opina.
Sep 16, 2008 | MSI Microstar KT6 Delta (MS-6590)...
SER? LA BIOS O EL HHDD MUY GRANDE??
NO NECESITAS ACTUALISAR EL BIOS,ESTE TABLERO MADRE PUEDE LEER EL DISCO DURO.
LO QUE NECESITAS HACER ES CREAR UNA PARTICION DE 137GB O MENOS AL PRINCIPIO DE INSTALAR WINDOWS.
LUEGO PODRAS CREAR OTRA PARTICION DESPUES DE INSTALAR WINDOWS.
CLICK DERECHO EN "MY COMPUTER ICON"/MANAGE/DISK MANAGEMENT,Y SIGUE LAS INSTRUCCIONES.BUENA SUERTE
Jun 19, 2008 | MSI KT600 400FSB (KT6DELTALSR) Motherboard
Computers & Internet Logo
21 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
