Question about Sewing Machines
Timing is off
Won't pick up bobbin thread
  • Sewing Machines Master
  • 1,564 Answers
Congratulations you have diagnosed your machine. Now take it in for repair.
Posted on Jan 09, 2013
SOURCE: The machine won pick up the bobbin thread, it jams when starting
wont pick up thread from bobbin
Posted on Nov 28, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
  • 233 Answers
SOURCE: My bobbin thread won't pick up. Its a new
Generally, this is because the needle is inserted wrong or because it's bent. In the first case, the top of the needle (called the shank) has a flat side-this has to be inserted so it faces the back or away from you.
In the second case, when a bent needle stops the top thread from picking up the bobbin thread. Even if you think your needle is fine, change it to see if this solves the problem.
Posted on May 10, 2011
  • 233 Answers
SOURCE: Hi I just purchased a
Generally, this is because the needle is either inserted incorrectly or because it's bent. Even if it doesn't look bent, it can be ever so slightly that you can't even see it with the naked eye. See if changing the needle corrects the problem, and be sure to insert the needle with the flat side of the shaft facing away from you.
Good luck, Linda!
Posted on May 17, 2011
  • 415 Answers
SOURCE: All of a sudden the needle won't pick up the
Check the tension. Make sure the bobbin tension isn't too tight and/or that the top tension isn't too loose. If the bobbin tension is too tight it won't be able to be drawn up and make the stitch. If the top tension isn't tight enough it also won't be able to draw the thread up. They need to be balanced to work together.
Test the bobbin tension by dangling the bobbin (in the casing) by the thread and give a slight flick of your wrist. It should drop down a bit as the thread is released. If it hits the floor it is too loose btw. If it doesn't drop a bit without great yanking it is too tight.
Then check your top tension and make sure there's a bit of resistance when you pull on the thread.
If you're having a lot of problems first try sewing on a plain cotton material and examine the stitch when set to a wide zig zag. When you get it adjusted so it sews that correctly then go back to what you were sewing on and make sure you have the right size and type of needle and that it is inserted correctly.
One of those things should correct the problem.
Posted on Jun 11, 2011
JUKI BOBBIN THREAD WILL NOT FEED
Most machines require that the bobbin in the case unspool in a certain direction its considered common knowledge I guess because it doesn't seem to be written in the text of manuals... but is indicated in the photos. make sure it's unspooling correctly.
Secondly. Please make sure you have the correct needle for your machine. Some machines do not use a 15x1 (most common needle) Let me show you. (see photo below) Clearly the 241x1 won't fit into your machine. BUT the 15x1 will go into the machine that requires the 20x1.... and the result is it won't pick up the bobbin thread.
Start there. Then check your timing.
Sep 05, 2012 | Sewing Machines
PE-3000S Pacesetter won't pick up bottom thread
try changing the needle
also rethread the machine
clean under the needle plate & in the bobbin area for loose threads or lint
if these suggestions don't help the it's possible that the machine has jumped time & needs to be serviced
May 15, 2012 | Brother Sewing Machines
Bobbin thread won't pick up
rethread the machine top & bobbin
if these suggestions don't help the it's possible that the machine is out of time & needs to be serviced
May 11, 2012 | Singer 7444 Mechanical Sewing Machine
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Necchi model 3537 won't pick up bobbin thread
sewvacdoctor.com has a list on their site with helpful free tips. I found this site for you I think will get you on your way. Hope this helps.
Apr 03, 2012 | Necchi 3537 Mechanical Sewing Machine
Elna lotus
try cleaning under the needle plate & in bobbin area for loose threads or lint
try using a new needle--make sure the needle is inserted correctly in the needle holder
try rethreading the machine top & bobbin
if you try all these suggestions & the machine still won't pick up the bobbin thread then it's possible that the machine is out of time & would have to be retimed at a sewing machine shop
Mar 02, 2012 | Elna Sewing Machines
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Why won't the bobbin thread pick up?
have you tried changing the needle? if it's a new needle is it inserted correctly---flat side to the back of the machine---needle push up in inside the needle holder
have you tried cleaning under the needle plate & in the bobbin area for lint or loose threads?
have you checked the bobbin to make sure it's not warped
have you checked the bobbin is inserted correctly?
if you've already tried these things then the last thing that possible is the machine is out of time & needs to be serviced by a repair shop that have the correct tool to time it
Aug 29, 2011 | Brother XL-2600
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
