Question about Philips Phillips - 40" Class - Led - 1080p - 120hz - Smart - Hdtv
No picture for phillips 40 pfl3705d
No picture it does not show name or anything
    Top Expert:
  • Philips Master
  • 75,591 Answers
There is no raster to your TV I assumes. If the LED drive inverter board has damaged, there will be no back light, and so no picture. If sound is OK, suspect the inverter board. Check this for more details.
Posted on Jan 08, 2013
Pictures won't come on my pinterest. Just shows a blank page. When I get my name up it still won't show any pictures. What is the problem?
Pinterest won't come on for me. No pictures. Can't look up anything. I have had Pinterest for ages. I have 24k pictures. What is the problem? It comes on but page is blank AmanStino QUICK CHARGER 3 0 USB charger Multi Port Intelligent USB Wall...
Nov 30, 2016 | Pinterest Computers & Internet
Toshiba theaterwide hd
replace the lamp on your TV, but only replace it with PHILLIPS brand. Anything other than that, will not last. We just replaced ours with Phillips and the picture is much brighter. It really shows the HD quality of the tv.
Mar 24, 2014 | Televison & Video
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
I have a 60" rear projection tv and the picture looks like its missing a color the picture isnt distorted or anything but the colors are bad what could be the cause and the fix
sounds like a Phillips or magnavox that has bad CRT coolant which needs replacement. If so you can get the Phillips CRT coolant repair kit from www.tvrepairworld.com it comes with instructions and the coolant for all three CRts,
Mar 01, 2013 | Televison & Video
Sony Bravia model #KDL52WL130 worked fine for first year then picture went very dark for the 1st 30 minutes it was on but eventually cleared up. Now it takes longer and screen is completely blank. Sound...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years, some sooner, because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have problem in my Computer and then i have this in my flash drive too. problem is that i dont know wat type of threat came in my PC through net or Flash drive. it hides all my folders C drives, D, E and...
This is an executable virus in that once in it will unload up 40 different sub viruses i.e mainly trojans and worms. you must get ride of the executable before you can start to eliminate the others.
ESET smart security will do it
Nov 12, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Phillips Plasma Tv 50pfp5332d/37 has red pixels but no picture,what is wrong
if you are using a HDMI cable and it is just the picture not the tv controls that is red, the cable might be loose, but if it wont do anything and the tv controls don't show up or anything than that's not the problem
Oct 19, 2010 | Philips Televison & Video
Picture is showing red/blue/grey Phillips 50' rear projection T.V.
this sounds like a color wheel fault, you will most likely have to have this replaced, this is a common thing in rear projection TV's. It is not too expensive a fix. There are tutorial on the net if you wish to do this yourself. Simply Google the name and model of your unit and add color wheel replacement.
Mar 16, 2010 | Televison & Video
No picture shows
HI THERE, I HAVE A PHILLIPS 42 INCH PLASMA SCREEN TV ITS ABOUT 2 YEARS OLD THE SOUND IS PERFECT BUT THE PICTURE IS DEAD MODEL NO IS 42PF55200/10 I HAVE HAD IT GIVEN TO ME TO SEE IF I CAN REPAIR IT BUT AT THE MOMENT NO SUCH LUCK THANKS JOHN
Dec 30, 2007 | Pioneer PRO-1009W 57" Rear Projection...
Wont connect
Try using Windows Media Player (version 11 should be fine) to sync music files to it. Using drag-and-drop to the device folder only sometimes works (and usually doesn't).
May 31, 2007 | Philips HDD1630 MP3 Player
Philips Phillips - 40" Class - Led - 1080p - 120hz - Smart - Hdtv Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
