Lg tv is coming on but there is no picture just a line of colour/fuzz at the top ????
It's lock on bottom of screen
Posted on Jan 08, 2013
Siliconchip
  • 52 Answers
SOURCE: LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Posted on Jan 05, 2008
  • 3422 Answers
SOURCE: TLM 2619 MODEL-DISPLAY PROBLEM
The most common cause for the loss of picture is a bad Horizontal Output Transistor (HOT). but I would suggest you get a detailed estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system has failed. There are over 100 components in this section and any one of them, or most of them can be at fault. However, the most common failure is the VOT or vertical output transistor (which is often buried inside a chip).
The repair will cost around $250 plus or minus.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair..
Goodluck..
Posted on Feb 21, 2008
SOURCE: LG plasma tv
Most likely it's the PDP panel wires failure. It won't cost you more to repair then to buy a new one.
Posted on Apr 28, 2008
TV #1
  • 129 Answers
SOURCE: LG model 26LCF7D 2 1/2
Inside your LG there is a component call backlight inverter that is was cause of the loose of tone. Normally the part is located on the left side of the screen. You can call LG and they can give you the part number average cost is about $45 to $75.00 very easy to install.
Posted on Nov 02, 2010
mnwarfield10
  • 452 Answers
SOURCE: Hi, LG 42" today started
you need to take rear cover off to inspect whats happened ..u will see or smell what gone wrong if done asap... UNPLUG FIRST ....
Posted on Feb 27, 2011
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
A horizontal white line is appears in my LG Flatron colour tv in the middle of screen suddenly and the pictures disappears but the sound keeps on but when i restart the tv the pictures comes what would be...
Tap the top of the TV and if the picture comes on in full screen then it is possible that there are DRY SOLDERING points on the board.
use a good iron to touch up the soldering on the vertical and horizontal sections, the driver IC's. get help if you are not able to do the job but it seems a minor job.
Jul 05, 2011 | Televison & Video
LG model 26LCF7D 2 1/2 years old tv when turning on it takes about 10-20 min for the picture to come up and sometimes woudl loose tone now after two week the whole tv doesnt turn on at all the screan comes...
Nov 02, 2010 | LG 26LC7DC 26 in. LCD HDTV
Coloured lines down the right side of screen
if the lines extend top to bottom and are thin, then the LCD panel is most likely defective.
Oct 21, 2010 | LG 42LC2D 42 in. LCD HDTV
LG LCD Tv has sound but no picture only colour vertical lines. Can be fixed?
If your screen has a picture in the left corner with a small square with lines on it but still has sound...try this....
unplug your TV itself from the power source, then hold down the power button on the tv itself for 1 minute, then release.... Plug the tv back in and see if the issue is resolved. I just called LG customer support and a woman walked me through this process and it fixed the issue !!!! Hope this helps..
May 16, 2009 | Televison & Video
LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
Nov 12, 2008 | Televison & Video
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
