Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
My sandisk 8gb cruzer micro flash drive is not recognised, plug into my macbook or dell, lights up for second, flashes on screen, then off
Was working perfectly ok yesterday and I havent done anything odd to it
  • SanDisk Master
  • 27,725 Answers
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Posted on Jan 11, 2013
mumma_1
  • 903 Answers
SOURCE: how do i use my new sandisk cruzer?
insert the flash drive into your computer and wait for it to be recognised by windows. Once it has been recognised and installed it will tell you that it is installed and ready to use.
The just go to wherever it is on your computer that you have your photos stored, select your photos right click and click on copy, then go to 'my comptuer' and double click on your flash drive to open it and paste your picture there.
Or select your photos, right click, select sent to:- and send to your flash drive, it may be recognised as removable storage.
Posted on Nov 17, 2008
  • 52 Answers
SOURCE: How format SanDisk cruzer Micro 8GB
copy the files to you're pc, and if you use windows just go in my computer and right click on the flash disk icon and click format check the quick format box and the press format.
Posted on Jun 14, 2009
bob_computer
  • 3153 Answers
SOURCE: My flash drive wont do anything when i plug it to my computer.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 21, 2009
SOURCE: I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
Posted on Oct 09, 2009
P0W3R GL1CH
  • 185 Answers
SOURCE: Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Posted on Nov 07, 2009
My 8gb sandisk cruzer does not light up anymore and is not recognized.
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 29, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
To start with My 'Sandisk Cruzer micro 8gb' USB flashdrive has failed. Nothing has happened to it, like getting wet or anything, but when I plug it into the computer the orange light (the light that it...
well the flash might be corrupted if u have pluged it recently on some mp3 player like those in the care that work on the radio signal, the electricity circulation in those mashines can broke ur flash drive.
if u want to make sure it is broken, u should go to administrative tools, and choose device managment, then disk managmen, if its note there, then its a 90% broken flash drive.
Apr 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Oct 20, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a sandisk cruzer, led continuously lights
I"ve seen a couple of these do this and the flash disc is broken and not working. Probably nothing you can do to fix it.
Sep 30, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How do i use my new sandisk cruzer?
Nov 17, 2008 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
63 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
