Question about Mitsubishi WS-55813 55" Rear Projection HDTV
Picture rolles horiz.
And no sound
There is sound but no picture, the screen is black, what can I do about that?
horiz output transistor is out,may have poor horiz drive as well and the flyback transformer could be bad
Oct 29, 2009 | Televison & Video
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
TV HAS SOUND BUT NO PICTURE
replace the H.O.T horiz. Driver Transistor.
comen problem with this set.
Jan 13, 2009 | Sylvania 6432TE 32" TV
No power no picture no sound
You have a shorted power component. Probably either the voltage regulator or the Horiz. output transistor. Both will be mounted to a heat siink of some type. The Horiz. power circuits along with the flyback transformer power up 90% of most TV sets.
Geno
Feb 16, 2008 | Televison & Video
No picture
Possible IFT. or Horiz. drive circuit problem. Philips are noted for that.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
No power Up , No Sound , No picture
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Nov 22, 2007 | Sony KV-32S45 32" TV
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
Sony KV-32S36 32" suddenly stopped working, no picture or sound
Check soldered in fuse R607 in power supply circuit =
If open, replace it and bad converter xistors ( 2SC4834)
Next, replace shorted horizontal output transistor w/ first Quality.
Solder any / all bad connects,esp.horiz drive to base of horiz.
o / p xistor. Soldering is critical or it will blow up again......
Oct 27, 2007 | Sony KV-32S36 32" TV
Not showing picture or sound
replace flyback xformer (IHVT).Also,replace horiz output xistor w/OEM or better quality. any Questions??
Oct 01, 2007 | RCA F36650 36" TV
No picture has sound, then picture comes on after a while
check for a problem with the horiz.output circuit. maybe bad solder connections or the horiz.osc.
Sep 15, 2007 | RCA F27442 27" TV
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
