Question about MSI a6400-042us core i5-2410m dual-core 2.3ghz 4gb 500gb dvdrw
Possibly disabled my keyboard on MSI laptop how do I fix
How do I enable my keyboard NOT working
2 Suggested Answers
maxcarson
  • 7627 Answers
SOURCE: my msi cr640 keyboard is not working...please help!!!!!
Has there been any damage? Drop? Jarred? Possible loose connection? I'm sure you have unplugged, removed battery, plug in, rebooted? Are ALL you Windows and MSI updates current? You may have to open the laptop and verify the connection and repair/replace the keyboard. Take a look a MSI Support for a Manual and drivers: http://www.msi.com/product/nb/CR640.html#/?div=Overview
Posted on Apr 08, 2013
Msi keyboard not working
When you plugin the keyboard do you get indication that it is detected? If so you may need to go to your device manager and disable the laptop keyboard to enable the MSI one.
Oct 16, 2013 | Computers & Internet
My msi cr640 keyboard is not working...please help!!!!!
Apr 08, 2013 | MSI Computers & Internet
Touch pad scroll gestures very intermittent.works then doesnt
Hi tommymul6...
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 04, 2011 | Computers & Internet
I bought a new asus laptop 3 weeks ago, one of the reasons I chose it was the feature of disableing & enableing the mouse pad. (I'm 72 yrs, old & I have bad tremmer. Since I had a heartattack...
Disable / Enable the TouchPad Share « PreviousNext » Summary
On laptops, sometimes your TouchPad is disabled for no apparent reason. To reactivate it, first try restarting your PC. If there's no good change just try:
We need the software driver and your mouse are installed
This trick works in Windows XP and Windows Vista.
  • Go to Control Panel> Mouse> Settings tab of the device
  • Click (or to disable)
Notes:
  • On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, a ACER, just do Fn + F7.
  • You can click Reset device if neither of those solutions will work.
  • The official website provides synaptics drivers and software needed to run your TouchPad.
  • On the latest laptops, there is a special button to Enable/Disable the Touchpad.
  • HOPE THIS HELPS
  • NORMAN
Aug 23, 2011 | Computers & Internet
Hello, My daughter has spilled tea on the laptop and now the keyboard is not responding. I am not an expert in computers so my fix was to buy a USB keyboard and install the same and disable the driver of...
Have you tried the On-screen keyboard?
You didn't specify an exact operating system, so I'll assume you're running windows 7
Start --> All Programs --> Accessories --> Ease of Access --> On-screen keyboard
then try to enable wireless from there
Good luck
Jun 04, 2011 | MSI Wind U100-030US Laptop
Hi. I recently had my keyboard disabled because of sticky keys. I want to turn it back on, so that I can try & enable the wifi. I just looked in the bios, but cannot find the setting to re enable the...
Hi davelarz, these instructions will help you. *Note: "Everything that you do for the Keyboard!" "Can be applied with the same instruction to the Mouse." First, click on the "Start" button. paul7of9_163.jpg In the ["Start Search Window], type: keyboard. Now, Click on the "Keyboard" shortcut. It should appear at the 'top' of the list. paul7of9_164.jpg The "Keyboard Properties" window will open. You can (Test) to see exactly how your keyboard is responding. Select the [Hardware] button. Next, click on the {Properties} button. paul7of9_165.jpg Choose the (Change Settings) button. paul7of9_166.jpg Next, click on the "Driver" button!." "You will be in the 'area' where the "Keyboard" can be [Enabled / Disabled]. Next, "Enabled the Keyboard." Click on the (OK) button. "This should do it for you!" !Important: If you are still having the same problem? Check: the Keyboard {Status}. "Update the Drivers" Click on the "Properties" button. Select the {Update Driver} button. Next, click on the "Apply and OK buttons!" !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 13, 2011 | MSI Wind U100-016US Laptop
What is the P2 button on top on my laptop? above the keyboard , i am using cr420... please let me know abt its functions
I believe the P2 button can be used for whatever you want it for. It's programmable to be used as a shortcut to start software or things such as a webcam.
Mar 12, 2011 | MSI Computers & Internet
Hi i have a u135 and it hasbuilt in blue tooth but i donot know how to activate could u help
Not sure if this will work for your model but its worth a try. Copied from MSI support faq website
You have to press the WLAN button located right next to the power button in order to enable/disable the Bluetooth function. Press WLAN button once, Enable WLAN. Press WLAN button twice, Enable Bluetooth. Press WLAN button thrice, Enable both WLAN and Bluetooth. Press WLAN button four times, Disable both WLAN and Bluetooth.
Aug 26, 2010 | MSI U100-422CA Notebook
Some keys of keyboard not working . on MSI WIND NOTEBOOK .. So Please HeLp Me,,
Hi try to disable your internal keyboard and use an usb external keyboard if the problem is fix you need to replace your internal keyboard.
Mar 17, 2010 | MSI Wind U100-016US Laptop
MSI a6400-042us core i5-2410m dual-core 2.3ghz 4gb 500gb dvdrw Logo
54 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
