Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Sony handycam lcd sez 'cover not open'
No image in lcd or viewfinder... sound is recorded but msg 'cover not open' flashes during record and no image is recorded when cover is closed msg 'cover not open' is present, not flashing there has been no trauma to the camcorder hve tried tapping the lens to open stuck iris (?) but nothing... is this one of those defective ccd that sony will fix w/o charge? or something more nefarious?
Had same issue. Appeared to solve it by turning off USB Streaming when not connected to pc.
Posted on Aug 18, 2007
Maybe you have the wrong type of tape or check and change all of the settings to normal
Posted on Aug 08, 2007
SOURCE:
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
No image on LCD screen
It sounds like you're receiving partial information on the LCD screen and that the image sensor isn't sending information to the screen.
If you know the sensor is working by recording some video on an SD card and being able to view the recorded video on your PC, then there is a disconnect between the LCD and the image sensor.
If you are not recording video to your SD card and only get black images or no files, the image sensor is damaged.
If you are recording video, but no image appears on your LCD for internal viewing/playback, you can try a firmware update if one is available from www.insigniaproducts.com, but this is a discontinued item so there's not much available for support.
Hope this helps!
Apr 25, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
GR-D71, no longer records images
CCD (imaging chip) went bad and require replacement. Not a very expensive repair, but has to be done by professional.
Nov 04, 2009 | JVC GR-D71 MiniDV Digital Camcorder
No picture on lcd & view finder
PLease see http://www.fixya.com/support/t131881-sony_cam_recorder_wont_record for more information on this i have had the same problem, faulty CCD image processor chip.
Apr 01, 2008 | Video Cameras
Records audio but no video
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony DVD92 LCD/Viewfinder doesn't display image
I had this problem and called Sony. Apparently there was a problem with handy cams and they paid to fix it.
Dec 17, 2007 | Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Blank lcd screen
wires have come off the ccd ! canon will fix free of charge,go to canon support
May 31, 2007 | Canon MV600i Mini DV Digital Camcorder
Lcd monitor and viewfinder not working when i try to record myself.
the flex wire of the lcd monitor is have a open line that why it is not functioning....there is also a switch to on the viewfinder connected to lcd....in some model even the lcd is damage you can still use the viewfinder...
Feb 17, 2007 | Panasonic PV-GS31 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
346 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
