I am getting a QDMA error message when i start up my computer can you tell me how to fix that error message
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Posted on Jan 08, 2013
Error message in odometer area
Get a scan tool and see what codes are stored in the computer.
Apr 14, 2014 | 2005 Dodge Dakota - Quad cab, 5 3" short...
I get the message - error initializing updater interface. = when I try to update my security program
In order to fix this error message you need to fix registry errors of your system, you should apply a professional Registry Repair tool to deal with all of your system errors including dll error, registry error and more.
For more you should visit: Fix Computer Errors Improve Its Performance
Jul 22, 2011 | HP Computers & Internet
Starting the PC have got error on HP 1730 Monitor error message, OSD Lock out. Can you please tell me how to solve this issue?
How to Unlock an "OSD Lockout" Problem
smilie-tag.png monitor, osd lockout folder-category.pngPosted in Fixes ' Comments (32)
osdlockout.jpg This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
Fix One: Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two: Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three: Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four: The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
If you know of any other fixes feel free to contact me. Good luck!
Having other problems with your computer? Simply scan your computer for free to identify problem areas.
Techbelkin please rate me
Nov 02, 2010 | HP 1730 LCD Monitor
I have a Dell Inspiron 6000 with windows XP, McAfee Security Suite, and a Verizon USB for internet. When I turn it on I get an error message: dlbcserv.exe has encountered a problem and needs to close. ...
This error message is a result of your Dell printer software functioning improperly.
This is a 'quick fix' to get rid of the error message:
  1. click 'Start'->'All Programs'->Startup
  2. Right click on dlbcserv.exe and click 'delete'
PS: dlbcserv.exe is a Windows process installed alongside Dell Photo Printers and provides additional configuration options for these devices. Although it is not an essential process for the operating system, you should not remove & uninstall it unless it is causing serious problems and errors.Dlbcserv.exe is a Windows file created by Dell. The file is usually found in Program Files\Dell Photo Printer 720\dlbcserv.exe folder. If you find it anywhere else, Please note that dlbcserv.exe could be a virus, trojan, worm, or spyware. Scan your computer with an antivirus software to make sure it is not infected.
Aug 10, 2010 | Dell Inspiron 6000 Notebook
Download icuin36.dll. The computer tell me that It can't find this file and I should to get it. Could you please tell me where can I get it? And very often my computer close down some programs because...
David
Try this first Click on the Start Button
Go to Run and click on it
In the Run box type the following:
regsvr32 icuin36.dll
If it is successful it will tell you and the problem should be fixed
If not try this download
http://kromann.info/icu/icuin36.dll
DLL (Dynamic Linked Library) Files:
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Steps:
  1. Download the DLL file using the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
  2. Backup the old version of the DLL file.
  3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\icuin36.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\icuin36.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\
icuin36.dll
Oct 14, 2009 | Computers & Internet
When i turn on my computer a bow comes up saying MMload dve.exe has stopped working how do i fix this problemm what is this
Hi
If your computer works fine even though dbe.exe is stopped then you can prevent that message coming up by going to start>>>run then typing 'msconfig.' Go to the startup tab then uncheck the box next to the process with the problem. This will prevent it running so you will not get the error message.
I think you may have made a typing error when you made this question - if you could tell me the exact message I may be able to assist you a bit more specifically. Or perhaps you typed it perfectly and it's just a very rare process!
Hope this helps
Philip
Jul 15, 2008 | Computers & Internet
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll
I followed these steps and haven't had any issues since:
1. Go to START menu
2. Select RUN
3. Type MSCONFIG and click OK (or press ENTER)
This will bring up your System Configuration Utility window.
4. Select the STARTUP tab.
5. Find M3PLUGIN, untick it, select APPLY and then OK
This will bring a popup dialogue box stating the following:
"You must restart your computer for some of the changes
made by System Configuration to take effect."
6. Select RESTART.
When your computer restarts, you should no longer receive that message.
Jun 30, 2008 | Intel Motherboard
DMR-ES10 DVD Recorder T112 error message
Can you press Enter when you get the error message? That will tell it to diagnose the problem. Tell me if that works. The manual can be found here. I can't find the T112 error you mentioned though.
http://panasonic.ca/PDP/OperatingInstructions/dmres10s-oi-eng.pdf
Reply if you need further assistance.
Oct 28, 2007 | Panasonic DMR-ES10 DVD Recorder
Error message
Details please. Computer Type Operating System etc. Try booting from your OS CD, and see if you can get to a recovery console or DOS prompt and read the drive.
Jan 01, 2007 | Seagate Barracuda 7200.7 80 GB Hard Drive
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
