Question about Car Audio & Video
My hyponics 1500 watt amp wont work
Da amp light was green then it turned red and ramain that way. nothing is burn and the amp get good power i wnna know what can i do to fix it?
  • 67 Answers
If u say nothing is burned on the amp then check for a faulty speaker connected to it
Posted on Jan 20, 2009
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
When I turn on microwave oven fuse is burn out right a way. Thank you
Fuses burn for a reason: because the circuit is being overloaded. There could be several causes, first determine what else goes off when the fuse blows. All of the things that go off when the fuse is removed/blown/burnt are on the same circuit. A microwave is a heavy load, somewhere between 750 watts and 2000 watts, depending on the microwave. Remove other heavy loads (items which use lots of power) from the circuit. A 15 amp 120 volt circuit in a residence is good for 1800 watts (or 1440 watts continuously). If you had a 1500 watt microwave and four 100 watt light bulbs on the same circuit, you would be overloading the circuit. With a microwave, it is best to have it on its own circuit with nothing else (if possible). The fuse may also blow or burn in this situation if there is a problem with the microwave.
Oct 05, 2011 | Microwave Ovens
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
I have a DA 1200.5 5 channel amp. It stopped
diconnect all your speakers from the amp and see if the light turns green. if it does, reconnect one speaker at a time to find out what speaker is making the amp go into protect mode
Feb 24, 2010 | Crunch BlackMaxx BLX2000D Car Audio...
They just turn off and wont work anymore
if the amp does not turn on then try to move the ground to a better spot
Nov 26, 2009 | Car Audio & Video
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Car Audio & Video Logo
256 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
