Question about Lexmark Impact S305 - multifunction printer / copier / scanner color
Lexmark printer not dispensing ink
I have the printer plugged into my laptop via USB. The ink levels are all more than half full. I tried to print a two-page document. The printer's first attempt left me with one page missing the black font but printing the colored background perfectly, and the second page was almost entirely missing its black font, but printing the blue fonts perfectly. I tried twice more to print the documents. Both times resulted in completely blank pages being produced. The printer gives no indication that ink needs to be replaced or that there is anything functionally wrong.
  • Official Brand Answer
  • 3,344 Answers
First, make sure you are using genuine Lexmark cartridges.
Second, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, please perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If it still doesn't help, please contact our technical support team.
Posted on Jan 09, 2013
Ajkill
  • 2035 Answers
SOURCE: black ink
Print nozzles will be at bottom of cartridge...Make sure that u do not wet copper contacts ... first try using dry paper towel and check where ink comes and follow the procedure given below....
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
  10. Check the warranty and try to get replaced
Posted on Mar 10, 2008
  • 12 Answers
SOURCE: recently refilled cartridge #70 on
It sounds like bad cartridge. Inkjet refilling only works sometimes, If there was any old ink in the cartridge there could be a bad mix or even dried ink getting into the head
Posted on Aug 14, 2008
leroyal
  • 2120 Answers
SOURCE: when i receive a
Unplug the machine and replug.
Are you using GENUINE HP cartridges?
Posted on Sep 01, 2008
pineworks
  • 4041 Answers
SOURCE: error #1203
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted on Apr 25, 2010
  • 51 Answers
SOURCE: Prints PDFs VERY, VERY Slowly...Something's Wrong...
See if print spooling is turned on. If using windows check the control panel or use task manager to see if spooling is active and running
Posted on Jul 11, 2012
Why was my printer showing my print level to be 3/4 the way full for both the black & color, & then I went to print again and there are ? marks on my ink levels, & a error that says cartridge problem?
printers are calibrated to only measure ink levels for original cartridges ( Lexmark)
if you refill or use generic cartridges the machine will not read the levels and will send a ink level warning or will not print because it thinks the ink is out and will not work to protect the printer
Talk with a lexmark service center for proper diagnosis
Jul 25, 2015 | Lexmark X2690 All-In-One InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X2550 ink cartridge refill
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Mar 31, 2009 | Lexmark X2500 All-In-One Printer
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
Maybe you can try to rest the black ink level 1st. To reset the ink level:
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
Printer cartridge is a refill and does not seem to be recognized
Maybe you can try to reset the black ink level 1st. To reset the ink level:
Hope this help.
YBC (/\)
Dec 23, 2008 | Lexmark X2500 All-In-One Printer
Printer shows ink levels full, but nothing prints...
Yes .. The cartridges can dry up and or nozzles/heads get plugged. I ma not completely familiar with this printer but if it has a cleaning utility use it.
Nov 23, 2008 | Lexmark Z640 InkJet Printer
My Lexmark x4850 all in one won't print documents from one of my computers but will for another one. Also the computer that it won't print from also can not tell me the ink levels for the printer. How do...
Ink level reporting is a problem for most lexmarks. Check for new software updates. Further I'd need to knwo what type of network is being used or if you are connecting each computer directly to the computer via usb/parallel port. If it is the former (which I assume it is) then you need to make sure that the computer that can't be printed from has the proper permissions to access the printer, and is capable of seeing it on the network. Further, you should check your router's printer control and recognition software if its a Linksys router.
Aug 30, 2008 | Lexmark Office Equipment & Supplies
No ink coming from cartridges.
Sounds like maybe the nozzles are clogged up. Try using the printer maintenance utility to "Clean Nozzles". I think for most Lexmark printers it is call the "Lexmark Solution Center" in your Windows Start Menu. If that doesn't work, try maybe wiping the cartridge with a damp paper towel at the place where the ink comes out.
Apr 15, 2007 | Lexmark X2250 All-In-One InkJet Printer
Lexmark X5150 No printing
uninstall the printe driver,then try reinstalling the printer back.if no luck,change the usb cable or printer cable as the case may be,if doesn't work,try using the printer on a friends machine. did it work?let me know. eyo7 eyoifiok2005@yahoo.com
Sep 01, 2006 | Lexmark X5150 All-In-One InkJet Printer
Lexmark Impact S305 - multifunction  printer / copier / scanner   color Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
