Question about Reebok Exercise & Fitness
Reebok 8700 es treadmill walking belt is loose
Is there a way to tighten the walking belt?
    Top Expert:
  • Reebok Master
  • 12,223 Answers
Use the video and proceed according.
God bless you
Posted on Jan 08, 2013
  • 6 Answers
SOURCE: how do you adjust the belt on a reebok 500 es treadmill?
http://www.iconservice.com/reebok
Posted on Apr 18, 2009
  • 40 Answers
SOURCE: I have lost my key for the Reebok Treadmill
Any magnet will do. Otherwise order a new one from the manufacturer, other retailer or ebay.
Posted on Nov 01, 2009
SOURCE: how do i unfold the reebok 8700 es treadmill? Just
We have a Reebok 8700 treadmill and need to get it downstairs-what is the easiest way to take a small amount apart ?
Posted on Mar 04, 2010
maxtreadmill
  • 832 Answers
SOURCE: Reebok 8050es treadmill walking belt has started
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
Posted on May 06, 2010
SOURCE: hi my reebok treadmill was plugged in during a
how do i replace the drive belt on8700es
Posted on Aug 07, 2010
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
I have a Reebok treadmill. The belt stops while the motor continues while walking on it. What could be causing this to happen?
the drive belt is too loose. you need to tighten the belt that drives the front rolller, which drives the walking belt. depending on the type of treadmill there shoudl be a way you can do this by loosening the motor and adjusting that to tighten the belt. it could also be that the belt needs to be replaced and also could be the walking belt. you should try to tighten the walking belt first. that is at the end of the treadmill where you walk on it. there are two holes one on each side of the treadmill where teh belt goes back under the treadmill. there are allen key bolts that you need to tighten clockwise one turn then try the treadmill. if it doesnt tighten then turn another full turn. if not tight enough then it might be the drive belt. if you tighten the walking belt all the way then try to tighten the drive belt.
Jan 28, 2011 | Reebok Exercise & Fitness
The belt is sliping as I walk or run
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Aug 02, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
May 05, 2010 | Reebok 8050 ES Treadmill
How do I unfold my Reebok 8700 i fit? I folded it
Hello there, If you stand behind the machine you should see the safety latch mechanism (round knob on the long section in the middle when the unit is raised) You will need to push up slightly on the walking belt section while pulling out the knob located on the safety rod. While pulling out the knob lower the unit about 3 inches and then release the knob. If you release the knob too soon it will catch back in the hole again. This should release the unit.
Good Luck! Tim
Feb 12, 2010 | Reebok 8700 ES Treadmill - Silver Service...
How do i unfold the reebok 8700 es treadmill? Just moved and have no idea. HELP!
Feb 02, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Reebok Vista belt not working properly
There could be 3 different problems with this machine.
1) loose drive belt (this model has a spring loaded idler that tightens the tension)
2) Bad front drive roller (you wil hear the pulley spinning freely on the front roller if the roller is bad)
3)Last is possibly the walk belt itself. May need to be tightened or replaced.
To try to tighten the walk belt, go to the end of the walk belt and find the 2 adjust allan screws in the end and tighten them 2 revolutions clockwise on both screws.
Hope this helps a little. Tim
Nov 25, 2009 | Reebok Vista Treadmill - RBTL13305
Exercise & Fitness Logo
55 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
