One of my Stanton T60's isn't making a weird humming noise when turned up. The other deck is set up exactly the same and is working sound. when I move the phono wire, the sound changes. Ive ch
    Sergeant:
  • 432 Answers
No bay 11, that's a bit nonsence and quite expensive. There ain't a cable in the world with the right impedance, since it's no constant sinus/ triangle, so you never have a perfect match. When you buy interconnects from 2000euro it amazes me that they don't even come to your home for measuring. But those peoples don't know what they sell and just repeat the nonsense talk of the distributeur, which also are commercial and no technical peoples.
gr richard
Posted on Jul 23, 2014
  • Audio Player... Master
  • 5,158 Answers
I suggest (if you can) to replace the wires in question. You can get some high quality ones if you shop around.
Posted on Jan 16, 2013
djproaudio
  • 515 Answers
SOURCE: New RCAS on Technics 1200 Getting a Loud Buzzing Noise
It is not suggested that you remove the ground cable. Performing the mod for the ground by soldering a bridge on the circuit board doesn't really do anything either than remove that buzz/ground hum. You've essentially removed the wire that grounds the turntable cabinet to the earth. The buzz is gone, but now your turntable is no longer grounded properly.
I would suggest replacing the ground cable to it's original state, then attach the Monster cables.
If this does not work, then either there is an issue with the soldering to the board, or the board itself might be damaged. You might want to look at the trace paths to make sure none are lifted, or damaged in any way on the board. Another issue might be faulty tonearm wires or not properly soldered wires.
FYI, monster cables are not good for this purpose. I would suggest the following cables:
MOGAMI RCA CABLES
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Apr 30, 2009
  • 104 Answers
SOURCE: hum when turntable connected to phono sockets on amp
this turntable absolutely came with a ground wire that must connect to the gnd connection on the amp. maybe it got torn off or something but there should be clues on the back of the turntable as to what happened to it.
once the lead is found it must be connected to the amp gnd connect to get rid of the hum. this might require someone with soldering skilz or what have you in order rig up a new wire.
a tech might have to remove the bottom and solder in a new wire if it is cut or ripped off at the housing. This is common as people forget to unhook the gnd wire from the amp when moving things around.
Posted on Feb 11, 2009
  • 7 Answers
SOURCE: Buzz coming from speakers on phono input
is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
Posted on Jun 21, 2009
Grubhead
  • 5158 Answers
SOURCE: Gemini XL-BD10. Always worked fine. Started
Check the internal circuit of the deck, follow the leads from the cartridge. Perhaps a faulty resistor or something else in any pre-amp. Make certain also it's not your amp that has not got a faulty phono pre-amp stage.
Posted on Sep 06, 2009
funkyparrot
  • 5 Answers
SOURCE: i hooked up my new stanton t-60 turntable to an
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
Posted on Jan 17, 2010
High pitch noises.
It sounds like feedback hum. Most likely caused by the settings on your computer. Try adjusting all the sound settings. Especially record settings.
Sep 01, 2017 | Numark ttUSB Turntable
Humming noise in 2004 envoy sounds like tire hum but isn't
Could it be a rear wheel bearing? Also check the condition of the tires, severe cupping can make a heck of a noise.
Aug 10, 2012 | 2004 GMC Envoy
Stanton deck issues
Does decks are too bad build, i gave them away
Jul 23, 2012 | Stanton ST-150 Turntable
Spinning guide(?) pin humming / buzzing
Since the unit stops it's noise when the capstan shaft is stopped, something I might add that you should never be able to do in a good deck, the noise is most likely coming from the motor not being grounded properly. This will be more a buzz sound than a hum. I am servicing decks these days and am not too expensive but that depends on what you consider expensive. The unit needs a checking out if you are going to use it long term anyway. I am near Chicago if you are interested.
E mail- skywavebe@sbcglobal.net
Jul 20, 2012 | Audio Players & Recorders
Technics SL1210 mk2 loud hum, it's not the rca or grounding cable...
This normally happens when the carts are removed and the amp is up. Its called microphonic-ing. Cheers john. Styluscity.
Apr 15, 2012 | Technics Audio Players & Recorders
Both Technics SL1210 mkII's loud hum and almost no sound...
You seem to have some feedback hum from somewhere. I would think it might be caused by a faulty connection somewhere.
Mar 12, 2017 | Technics Audio Players & Recorders
My sony alpha 300 dslr is making weird noises
i had exactly the same problem today with my a200, was is like a jammed sort of sound? like a drilling sound almost :S
im so annoyed. why is this happening?
Feb 13, 2010 | Sony Alpha DSLR-A200K Digital Camera
Hi, Meens here In my Acer Aspire 5920 Vista home preimum getting weird sound frm inbuild microphone after swtich on n the sounds stops after plugging headfons :(
The usual cause of microphone noise is caused by audio settings where the microphone gain may be turned up to high causing it to pick up noise from the computer or built in speakes. This can cause noise ranging from an odd hum to a high pitched squeal.
Check your sound setting first
Jul 12, 2009 | Acer Aspire One PC Notebook
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
Humming noise/ feedback
your mixer should be grounded by the power cord, and the decks have a seperate ground wire which connects, usually on a screw terminal, to the mixer, which provides the ground for the decks. I would try the headshells to make sure they are tight and connected correctly also make sure the power socket on the wall is earthed properly.
Feb 19, 2008 | Stanton STR8-150 Turntable
106 people viewed this question
 Grubhead
Grubhead
