Question about Refrigerators
All my profile appliances have yellow plastic.
    Genius:
  • Refrigerators Master
  • 1,669 Answers
You could get some refrigerator paint at the hardware store and paint the handles white, or you could use white contact paper to cover the yellow.
Posted on Jan 10, 2013
Hotpoint Aquarius WD63 door won't open
on some hotpoint models you can remove the front kickplate and on there will be a yellow or green plastic pull toggle, pull this and it will bypass your door lock, if your appliance does not have this then you will need to unplug and leave unplugged for 10-15 mins to reset the door lock, you will however more than likely need a new door lock
Apr 07, 2014 | Hotpoint Aquarius WD63 Front Load...
The plastic panel where you turn washer on , I pushed too hard and it broke but I don't know what its called to replace it? After it cracked machine won't turn on. Need your help please.
Plastic control panel. It could also be electrical panel. You can order part from the Internet. Just use "appliance parts" Then pick one of many appliance part vendors. They will have sub-catorgies; such as, washer, dryer, stoves, etc.etc.
Well, Flower Lady check your local dealership for pricing. This will give a good estimation to buy parts from the vendor on the internet. I have saved money buy from internet but you need know your prices on parts. So, check the prices before buying and find the vendor that will ship free. GB...stewbison
Aug 21, 2011 | GE Profile WPRE6100G Top Load Washer
The white plastic(?) full length door handles OUTSIDE the refrig are turning yellow on my white, side by side refrig. What can I purchase or use to re-whiten them and make them look clean and white again?
That yellow coloring is most likely a result of the white paint coming off, and the yellow plastic color showing underneath. Other than painting them with a good paint, which you would have to ask a paint expert for the proper type, my suggestion is to replace the handles altogether.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New water pump isn't working. There were 3 wires connected to my old water pump (red, green with yellow stripe, and black). That old pump has apparently been replaced with this part number (AP3160348) and...
lucky that the machine is plastic or you would be getting a shock
red wire is active , black wire is neutral and the green with yellow is ground
all of the wires have a color code for a purpose and must all be connected correctly
connect the pump correctly and the fault will dissapear
May 12, 2017 | GE Profile WPRE6100G Top Load Washer
The plastic "feeder arm" in the icemaker has broken apart and won't "push" the icecubes out to be dispensed in the door
I think you mean the ice striper part number WRX10085 and I also believe that will be the only replaceable part on the type of ice maker you have.You can find that part here=> GE Artica Profile Technical Information or Here=> WRX10085 where there is no photo. If for some reason the model number does not match your refrigerator let me make changes to your part numbers. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Feb 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
I'm installing a GE slide in oven. Is there something I can use to fill in the space between the over and the counter top? Have a 1/8 to 1/16 inch gap. Thanks...
Most appliance parts houses have a t-shaped long trim piece made out of plastic or metal that is designed to be cut to fit into this space. Try Reliable Parts at 1-800-666-0313 Good Luck, Appliance Specialists
Dec 14, 2009 | GE Profile JGS968SHSS Gas Kitchen Range
My ge profile top load washing machine will not finish it's cycle and empty the water?
Sounds to me that you need a new timer,the timer is responsible for All the functions of a cycle!!! if you remove the timer and take it to an appliance parts store(check the yellow pages) they should be able to supply you with a replacement.
Nov 06, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Refrigerator model #TXP24PRYE with yellowed handles
Spray with clorox all purpose cleaner and scrub it with hot or warm damp wash cloth.If the handles are plastic, Krylon makes an excellent line of spray paint products that bonds to plastic and adheres to the surface. Most spray paint products only coat the plastic and on a surface like a handle that will be used constantly, is easily scratched or peeled. The Krylon plastic paint bonds to the plastic surface and is very durable. The one down side is if you paint the handles and don't like the results, there is no going backwards, you can't remove the paint once it has cured.
Thanks.
Jun 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
