Question about Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over the Range Microwave Oven - Stainless Steel
I have Whirlpool gold GH5184XPS its not heating. how to troubleshooting the problem?
I any has the diagram to locate magnetron, transformer, capacitor, diode and how to check whats gone bad will be of great help. What to do it my self (because of cash crunch) All ideas are welcomed. thx. Raj
  • Whirlpool Master
  • 9,098 Answers
There will be a technical sheet hidden behind the controller assembly or elsewhere.
There is a YouTube video here which shows you how to remove the controller assembly in about 5 minutes.
You can also find it online here.
It may be a bad door switch, controller problem, inverter problem, or defective high voltage part.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jan 09, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: whirlpool mh7140xfq
Here are some links you can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
The average DMM doesn't have a high enough voltage to bias a high voltage diode, which is several diodes is series.
If the diode was not shorted, it was probably okay. They almost always short when they go bad.
I don't advise people on measuring a microwave's high voltage. The voltages can be instantly lethal.
The tech sheet should show you how to measure the resistance of the windings of the high voltage transformer. You know you're getting 120V on the primary.
The capacitor is probably okay because they usually short when they fail, and that would blow the fuse when you hit Start.
Look for corrosion or signs of melting on the FA terminal of the magnetron (and on the other temrinal if someone reversed the wires). Look fro a loose connection at the magnetron.
If these connections are fine, then you probably have a bad magnetron.
Probably the best prices on Whirlpool parts can be had here.
Posted on Oct 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave malfunction
Wow. A shocking tale...
It sounds to me like they're guessing ("shotgunning" as it's called) and don't have a clue how a microwave works or how to fix one.
They can't possibly be a Whirlpool-authorized service center can they?!
They apparently replaced two parts that did not fix it, so they should not charge you for those parts, or they should put your old parts back in. What are the odds they would have them still?
If you've not paid them any (or much) money, I would tell them to keep the oven and buy yourself a new one.
If you have paid them anything, I would insist on a full refund and your microwave back with all your original parts (if available).
If you hired someone to paint your house, and they only painted your window panes, should you pay them for the labor or the paint??
But to be honest, I would not trust this shop as far as I could thrown it. If you do get this oven out of the shop, the next servicer may find a whole lot of bad parts all of a sudden... Know what I mean?
If they give you any more trouble, I would go straight to your State Attorney General's Web site and file a complaint with their consumer protection division (or at least threaten the shop with this action).
A State government's Web site is at www.state.xx.us or www.xx.gov where xx is replaced with your Stat's official two-letter abbreviation.
Good luck.
Posted on Oct 24, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave not heating, unit buzzing, strong ozone type smell
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
With a smell present, I would not suspect the capacitor, but here are some links you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
I would most suspect the magnetron or transformer.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 25, 2008
KevinWhite
  • 1902 Answers
SOURCE: where is the location of
Hello & Welcome to FixYa
You can check this parts image, part#13 is the magnetron located next to the turntable plate. Please get back to me if you have any other questions.
Kevin
Posted on Aug 24, 2011
  • 1833 Answers
SOURCE: microwave runs but does not
Not heating is a problem that can be caused by three things.I'll list the most common solution first, the magnetron that actually does theheating has gone bad. It is possible for you to also have a bad high voltagediode that has opened up, solution two, or solution three is the high voltagecapacitor is not working properly as well. But mostprobably it is your magnetron that is bad. If you are not do it yourselferyou'll need to take it to a repair shop to replace. However, if you know how touse a screwdriver and can unplug a couple of wires with spade terminals onthem, then you can take it off yourself, find another one and replace it thesame way you took it off. The magnetron sits behind the control panel of yourmicrowave but on top. It has cooling fins on it and has 2 terminals maybe threedepending and make and model that plug into it. It has 4 screws that are easyto get to that actually hold it in place. If you do not have a good localsource like an electronic parts supply place then you can find the rightmagnetron at www.mwoparts.com. Be sureyou always unplug the microwave before touching or trying to take the heatcover off and then when you take the magnetron off also. If themicrowave appears to be working normally (i.e.: light comes on; timer countscorrecting, turntable turns) but there is no heating of the food, it could alsobe your high voltage fuse - normally 5kv 700mA or 0.7A. Check and if foundfaulty replace with same specification component.
Hope this will help you. Good Luck.
Posted on Sep 02, 2011
How CAN i TEST MY MICROWAVE?
Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board.
Jul 24, 2014 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
Locating reset button on my microwave
To my knowledge none have a reset button or circuit breaker. If the unit is total dead there will be (has to be) a fuse inside the unit.
Dec 06, 2012 | Whirlpool Gh5184xps Microwave Oven...
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
Whirlpool gh5184xps over-the-counter microwave no power
There is a high voltage fuse in the unit attatched to the high voltage capacitor, it is the most common problem for microwaves not working. Also check the protective diode,the high voltage capacitor as well as the transformer if the fuse is ok. Good Luck.
Nov 12, 2009 | Microwave Ovens
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
We have a whirlpool GH5184XPS-4 microwave that we are getting an F7 error on. We removed control panel and parts of the board were scorched. we resoldered in loose parts still have smae problem
From the technical sheet usually located behind the control panel or grille:
F7 Power to magnetron interrupted
1. Check the door, hinge and cavity front alignment. Adjust as needed.
2. Check the operation of all interlock switches.
3. To check the over-temperature protection for the magnetron, unplug microwave oven or disconnect power.
4. After 40 seconds, check to see whether this solves the problem.
5. If this solves the problem, check the cooling fan for proper operation or blockage.
6. Unplug microwave oven or disconnect power.
7. Check resistance of the magnetron thermostat. It should be close to 0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected to plug P2 on the display PCB. If necessary, adjust or reconnect.
9. If interlock switches operate correctly, replace 1100W inverter.
10. If problem persists, replace electronic control.
11. Plug in microwave oven or reconnect power.
Dec 06, 2008 | Whirlpool GH5184XPQ Microwave Oven
Nov 25, 2008 | Whirlpool RMC275PD Microwave Oven
MH1170XSB-0
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Sep 29, 2007 | Whirlpool MH1141XM Microwave Oven
Microwave ahs power but doesn't heat.
check the magnetron and related circuit and high voltage fuse and high voltage diodes, etc..
Sep 24, 2007 | Whirlpool GH4155XP Microwave Oven
Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over the Range Microwave Oven - Stainless Steel Logo
155 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
