Question about RoadPro AC/DC Power Inverter 2000/5000w
I have a RoadPro 1500 DC to AC Power Inverter in my tractor trailer and have become very dependent on it. It came with the truck I bought and worked fine for approximately 3 months. Now when I try to turn it on all I get is the red fault light. Can you suggest a cure? Thanks! Dave
  • Anonymous May 21, 2009
    Power comes on with one green LED but appliance will not work.
    Problem Solver:
  • 11 Answers
Maybe the fuse is bad......... the one i have has a fuse dont know if that one does
Posted on Jul 21, 2009
it has grounded out on you inside of your converter,Replace it.
Jan 21, 2011 | RoadPro 1500 Watt DC to AC Inverter
Getting fault light, what can I do? road pro 1500 watt inverter
Check the Following:
  1. Ground from inverter to frame is intact
  2. Positive leads are intact and clean
  3. Negative leads are intact and clean.
I hope this of help to you please rate if the answer is of any help. If I can help any further will be glad to. Good Luck and have a great weekend.
Apr 03, 2010 | RoadPro AC/DC Power Inverter 2000/5000w
I have a roadpro 1500 what size wattage of
depends on the type of oven but usually a comfortable load is 3/4 the size of inverter out put
Sep 19, 2009 | Electronics - Others
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Green and red light are blinking on roadpro 300 power inverter
    if the inverter is working and the fan is just starting and stopping the fan must be bad, but if it is not supplying power the inverter control is bad
    May 11, 2009 | RoadPro AC/DC Power Inverter 80/100w
    Can't get power to my RoadPro 1500 DC to AC Power Inverter
    I have had this same problem with several power inverters over time. The problem is usually one of three things.
    Those starting with the simplest.
    1. Too much current being drawn on the inverter.
    Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
    2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
    Solution (Replace the fuses)
    3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
    If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
    Hope that helps.
    Jan 20, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
    RoadPro AC/DC Power Inverter 2000/5000w Logo
    300 people viewed this question
    Top RoadPro Electronics - Others Experts
    Craig Butler
    Craig Butler
    Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
