Loaded Hunting Unlimited 2009 0n my new compter PC, cannot get screen to set to fit the screen, try all screen sitting low to high, Picture is to small or way to large. I was running XP and now running 7.
  • 2,878 Answers
Sounds like it using Window defaults.Try loading manufactures video drivers.
Posted on Jan 08, 2013
4 Suggested Answers
listeur
  • 88 Answers
SOURCE: dell d 600
Get the proper- FREE download from dell here: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R113575&SystemID=LAT_PNT_PM_D600&servicetag=&os=WW1&osl=en&deviceid=3083&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=6&fileid=148994
load that and see if it works. If it does not there is something faulty with the video hardware. Make sure to remove all the other video drivers in there first. Hope that helps!
Posted on Oct 31, 2007
eagle338
  • 4889 Answers
SOURCE: resolution problem
I had this issue sometime ago on my inspiron.Apparently your graphics driver is the culprit here. I would advise that you download and install the latest driver and see if it resolves the issue.
click here to download the driver
Also please vote for fixya if you found this post helpful. It will only take a minute or two
http://tu5.twiistup.com/entries?#1165
Thanks for using Fixya.
Sai.
Posted on Feb 08, 2009
  • 561 Answers
SOURCE: Hi i have a soney vaio, and when the compter
Hi
Please try the following
Press the fn key + the up arrow key (or the key which has a small sun type symbol on there) this will manually increase the brightness and leave it there
Please try and advise
Posted on Mar 10, 2010
The ground is rendered black on hunting unlimited 2010
I Have a much simpler solution Open the launcher then Advanced options Then change shader quality to ARB Minimum!
Jan 20, 2012 | ValuSoft Hunting Unlimited 2010 -...
I installed hunting unlimited on my computer and when I go to play it it loads to 98% and stops working eeror message says it has stoped working dont know y it a brand new game
Hunting Unlimited 2011 did the same thing to me when I tried to play. I installed it on Windows XP no problems. I don't know where on my laptop but it listed operating systems & I checked Vista & the software played just fine.
Feb 25, 2011 | Computers & Internet
Sys_no_graphics hunting unlimited 2010 windows 7 tried compatibility
just go in and vai documents folder Hunting Unlimited 2010 and
sys_no_graphics clears the error is so I hope I have helped
Theu
Nov 17, 2010 | ValuSoft Hunting Unlimited for Windows
I am trying to get my 'hunting unlimited 2010' game to work, but it does not even reach the main menu before it tells me the prism 3d engine has stopped working!!! Please help
Hi , i finally solved it .Before you start the game ,just go to advanced settings and change graphics to low . Change screen resolution to 800x600 . it will work . Change to high resolution after game starts .
Thanks
Feb 21, 2010 | ValuSoft Hunting Unlimited 3 for Windows
I just downloaded hunting unlimited 2009 sys_no_graphics problem
This is from the ValuSOft site. Looks like your video card does not mee the requirments for the game. You will need to upgrade the video card.
If your video card does fully support the necessary requirements, as listed on the box,
you may need to update your video card drivers.
You should update your video card drivers from the video card manufacturer's web site
and not the computer manufacturer's Website (IE Dell, HP etc)
Common Video card manufacturers are...
ATI's Home Page
nVidia's Home Page
Intel's Home Page
If you need assistance determining your current video card and manufacturer
please visit the following link. This link will guide you in determining your
current hardware and drivers.
Locate Video card model and drivers link
Applies to Versions: This article applies to
Hunting Unlimited 2009 All Versions Patch Download: None Article Last Updated: 12/26/2008 9:27:09 AM
Feb 12, 2010 | HP Compaq Presario SR2150NX PC Desktop
Installed Hunting unlimited but said sys-no-graphics
Thanks
Feb 10, 2010 | ValuSoft Hunting Unlimited for Windows
Pc gaming issue
i,d suggest your problem, is with either the Graphics card. Or your Memory is very Low. I,d go 512 meg RAM ( minimum ) Go To 256 Meg ( AGP Or PCI-e Card ) minimum.
Install Direct X 9 Or 10 if the new card supports It.
Also check The Speed of the Memory.
Final solution, is to free up some items From The start-Menu.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 19, 2009 | Dell Dimension E520 PC Desktop
Sys_no_graphics
for vista users and x64 users you need to right click the shortcut and select compatibility set the compatibility to windows xp and under settings check run in 640x480 screen resolution then ok back to the desktop. once the game lauches you can change the res back to whatever you want ok hope this helps GRUBBTEKK FOREVER
Jan 08, 2009 | Video Game Consoles & Games
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
