Question about Singer Touch and Sew Bobbins
Singer Touch and Sew 630 bobbin won't spin, I'm new to the machine but it worked when it was tested
I am new to sewing, the machine spun when I first got it, but the bobbin emptied, I took it out to refill and it was broken, I got new correct bobbin and now it won't spin to wind the bobbin at all..I don't know what I'm doing wrong or if something is wrong with it..thanks!
  • Singer Master
  • 18,424 Answers
  • 415 Answers
SOURCE: I amhaving trouble with the
Check the upper threading and make sure it is threaded correctly. When you pull on the thread before it goes through the needle does it give a bit or does it break? If it is breaking when you pull then the tension is way too tight or it is threaded incorrectly. Make sure it isn't looped around some guide along the line too.
For the bobbin thread... when it is in the bobbin case outside of the machine dangle it by the thread. It should hang there until you flick your wrist a bit, which should cause some thread to release and drop the bobbin down towards the floor a bit. (If it just pulls out right to the floor it is too loose). Most bobbin tension is tightened by a small screw on the bobbin case near where the thread comes though. Breaking thread would not be from the bobbin thread being too loose. Too loose would cause looping on top side of the stitch not breakage.
Make sure the bobbin is in correctly. You should feel and hear a slight "click" when the bobbin goes in correctly.
Posted on Apr 27, 2011
  • 5469 Answers
SOURCE: I received singer sewing machine
Singer has manuals for most of their sewing machines available at their site. For the 2623, the manual is only available as a bound copy for $15. Go to http://www.singerco.com/accessories/instruction-manuals and enter the model number then click Search.
I believe on this model, you fill the bobbin with it on the metal pin on the top right of the machine. With a metal presser foot in place, bring the thread up and around the guide that pin. Wrap the thread a few times around the bobbin. Set the lever to the bobbin winding position and begin winding. Stop and trim the excess thread from your initial wraps after it is fully caught. Then complete winding the bobbin.
(On other Singer machines, you fill the bobbin in place with the bobbin cover moved halfway open.)
I hope this helps.
Posted on Jul 08, 2011
  • 3 Answers
SOURCE: I have a singer 620
You have a Singer and Singer has a customer help line that is terrific or you can research your machine online at singer .com if you need the customer helpline I can supply it to you
Posted on Jul 25, 2011
  • 58 Answers
SOURCE: It dose not sew, and
It could be the bobbin tension, as Hans Pearson suggests.
It could be that you have forgotten to lower the pressure foot, or are sewing something so thick that the machine does not tension the needle thread.
The machine could be mis-timed. If it jammed and broke needles, the timing may have slipped. If this is the case, then you may need to have the machine repaired. there are instructions on the internet for how to re-time simple mechanical sewing machines, and adjusting the timing of the thread hook to the needle is not difficult. If you sew you have the required hand-eye coordination and attention to detail for the job, but it requires some mechanical skill to remove all the covers and then to reassemble the machine and a parts or assembly diagram is helpful.
Posted on Jul 28, 2012
small6363
  • 18424 Answers
SOURCE: singer e2 error
here is the manual
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Posted on Dec 15, 2012
Singer golden touch and sew model 630
This series of machines was nicknamed "touch and swear" and "sew and throw", as well as other, less polite, names, because the bobbin winding system is so touchy. Try a couple of new bobbins, and if that doesn't work, consult the nice folks at the yahoo group "wefixit": https://groups.yahoo.com/neo/groups/wefixit/info Most of the time, though, a new bobbin fixes this particular issue.
Jan 01, 2014 | Singer Sewing Machines
Singer Golden Touch N.Sew 630
it sounds like the machine may need to be serviced
Dec 21, 2012 | Singer 7430.CL Computerized Sewing Machine
Singer touch & sew 640 bobbin won't turn
is the bobbin in the bobbin case correctly?
is the bobbin wound correctly?
try taking the bobbin out & turning it the opposite way
let me know if any of the suggestions work
Apr 07, 2012 | Sewing Machines
Singer Golden Touch & Sew Model 750 sewing machine. Machine won't straight stitch, won't pick up the bobbin thread.
Try a new needle first failing that you may need to retime the machine, you can email me for an attachment of instructions kendourof@yahoo.com
Aug 27, 2011 | Sewing Machines
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Jan 19, 2009 | Singer 3116 Simple
Singer Touch and Sew Bobbins Logo
462 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
