Question about Kyocera Copystar CS-1820 Black and White Copier
I have tried to add a extra paper tray to my Kyocera Copy Star CS 1820 for legal size paper. The machine recognizes the tray but will not recognize the legal size paper. How can I get it to find the paper?
  • 105 Answers
System Menu/
Counter
�� or ��
Common Setting
Enter
�� or ��
Orig./Paper Set
Enter
�� or ��
Cassette# Set
Enter
�� or ��
Cassette# Size
Enter
Cassettes
Access Cassette# Size.
Where # is the cassette number.
If you are unsure how to use this route map refer to Accessing Menu Items on
page vii
2 Press �� or �� to select the paper size to be used in that cassette and press
Enter. The display shows Completed and returns to the Cassette# Set screen.
3 Press �� or �� to select Cassette# Type and press Enter. The Cassette# Type
screen is displayed.
4 Press �� or �� to select the media type to be used in that cassette and press
Enter. The display shows Completed and returns to the Cassette1 Set screen.
5 Press �� to select Back and press Enter. The display returns to the Orig./Paper
Set
screen.
Posted on Aug 27, 2009
  • 523 Answers
Go to the setting and the change the first try paper size.
Posted on Mar 09, 2009
  • Kyocera HP Expert Mar 19, 2009
    go to machine setting, machine setup, and change the size of the seconed tray to legal , this should be done manually .
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
I have a Canon ImageRUNNER 3235i black and white copier. I have the Cassette Feeding Unit-Y3 installed allowing two additional trays for legal and 11x17 paper sizes. The problem is that the copier doesn't...
This copier does not recognize the paper size automatically. Open the paper drawer and look at the right hand side you will see a dial, Turn that until the paper size you want aligns with the arrow. This sets the paper size.
Nov 03, 2010 | Canon ImageRUNNER 3235i Black and White...
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
PAPER TRAY JAM
Hello sir;Pull out the tray look inside the machineif you found any paper chip emove it otherwise clean out paper pickup roller with rubbing alcohol.
Jun 01, 2009 | Kyocera Copystar CS-1820 Black and White...
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
Mar 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Can you help with kyocera cs-1820
Look in the Document Processor, That is the auftomatic feed device.Look for a scrap of paper jammed in the machine.Try using a dustblaster(canned air) to blow the debris out of the feeder.something in the feeder is operating the switch that detects paper in the feeder.Good Luck
Feb 11, 2009 | Kyocera Copystar CS-1820 Black and White...
KYOCERA CS 1820COPIER/FAX
I don't work on that particluar product line so I can only comment on what zoom feature can do to copies in general
It could be that the zoom is too high to fit on 8/12 x 11 paper you may have to reduce it to get it to fit.
Otherwise you might want to check with a Kyocera tech.
Jun 12, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Copystar CS-1820 Black and White Copier Logo
272 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
