Question about Hoover AAA160 Front Load Washer
Hoover Vision HD 1600 AAA stops washing at any program and starts blinking "P" Pre wash
I cant let it work properly because it stops efter several minutes on all programs and starts blinking P even when it is not on Pre wash program. Thank you for helping
4 Suggested Answers
SOURCE: Hoover Nextra HNWF 3137 washer/dryer
I have the same problem exactly please send me the solution with confirmation of the exact part requested my machine is HOOVER HNL3137 1300rpm/7kg thanks
Posted on Jun 02, 2008
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
  • 24 Answers
SOURCE: My Hoover 1600 AAA Vision
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Posted on Jan 17, 2011
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
Jan 17, 2011 | Hoover AAA160 Front Load Washer
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Not working at all. my washer was on working and i heard a big bang and my electrics went off, i turned everything back on and the washer started up again but then stopped and now will not work. when...
The ticking that you hear is probably the timing motor for the dial.
Was the "bang" from outside the house? If so, then a transformer probably blew and hit your house with a power surge. Motor is likely damaged, and will need replacement.
If the bang was inside the house, the capacitor on the motor probably blew (unusual failure mode though), and will need to be replaced, motor is likely damaged as well.
Sep 18, 2010 | Hoover Washing Machines
Hi my sister has a hoover vision hd but cant get it to start the wash cycle
Is the water coming in, does the waterr level sensor work? if not check this out as the sensor must work for the cycle to start.
If this happens and the wash motor does not work, the check on motor, motor capacitor, program controller.
Please give a feedback to go futher.
Helpful?
Aug 20, 2010 | Washing Machines
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Apr 11, 2008 | Washing Machines
Hoover AAA160 Front Load Washer Logo
132 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
