Question about Garden
How do you increase reverse speed on a Husqvarna GTH 2754 Garden Tractor
Reverse is too slow
  • 37 Answers
SOURCE: Both forward and reverse speed are decreasing
Hi, check the main drive belt, the belt is stretched out. you need too replace the main drive belt.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 23, 2008
  • 95 Answers
SOURCE: husqvarna gth main belt keeps breaking
Make sure the mower rake angle is not too much,On level floor point one of the blades in a front rear orientation,measure height of blade from floor the front measurement should be no more than 1/4" lower than the rear measurement.If the front of the mower is too low the angle the belt has to run is too much and the belt will twist and wear rap[idly.To raise the front of the deck there are either one or two adjustment rods that attach the front of mower deck to frame tighten this adjustment up to raise the front of mower deck.
Posted on Jul 30, 2009
mickey813
  • 472 Answers
SOURCE: Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Posted on Oct 08, 2009
  • 420 Answers
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
Posted on May 27, 2010
  • 252 Answers
SOURCE: my drive belt for my
sounds like the belt has come off the from the the tension idlers
that are on the clutch brake arm bracket 1 wil be a flat idler and 1 will be a vee idler these 2 place tension on the belt for drive
and when clutched no tension is placed on it
there is also 1 more pulley in the drive line other than pto take off
it is about the middle and is a flat idler
please check website below for part diagram
http://www.partstree.com/parts/?lc=husqvarna&mh=29
select 2754 gls 2008
and go drive system
drive line and belt route will be shown
save a copy fyi
cheers hope it helps
paul
Posted on Aug 11, 2010
I need to know the placement of the deck belt on my husqvarna mower 26k54t. I think I keep twisting it the wrong way, which pulleys need the flat side of the belt on?
https://www.partstree.com/parts/husqvarna/mowers-lawn-garden-tractor/gth-26k54t-96043001101-husqvarna-garden-tractor-2006-03/mower-deck/
Sep 09, 2016 | Husqvarna Garden
Has very little power in reverse.
sounds normal to me none of that type run fast backward
Apr 22, 2015 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Husqvarna problems
Question is unclear because reverse slower than forward, for safety, is normal as long as pto...blade is running full speed. Please provide more background & overview detail to validate an actual malfunction requiring corrective action. Thank you.
Sep 06, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
Reverse goes slow to slower
bad reverse check valve take it in about 100.00
Sep 06, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
My husq. GTH 2654 riding mower goes real slow in reverse?????
sticling check valve have to take in to have looked at
Sep 06, 2014 | Husqvarna Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
My drive belt for my Husqvarna 2754 GLS has slipped off. The mower blades work, but it won't go forward or reverse. It doesn't look broken. I have checked all levers and trany switchs.
and go drive system
save a copy fyi
paul
Aug 11, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Oct 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
