Question about Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412
My shower valve changes water temp in a near by sink
If I turn on hot water in my bathroom sink only gets Luke warm, but if I leave water off in shower and only turn the thermostatic temp control to hot, immediately water in sink gets hot or very hot depending on what temp I set the showers valve at. I'm stumped? I did recently replace my hot water heater. Could there be some sort of issue there or is the problem in my fancy showers mixing valve? This actually has the same affect in other areas of the house. Guest bathroom has same problem. But I have a mixing valve in that shower too. Help!!!!!!!!!!
gary1121
  • 332 Answers
SOURCE: Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Posted on Jun 06, 2009
gary1121
  • 332 Answers
SOURCE: I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Posted on Jun 21, 2009
snap101
  • 117 Answers
SOURCE: grohe shower
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Posted on Jul 29, 2009
pipesster
  • 20 Answers
SOURCE: The temperature in my shower is very luke warm
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Posted on Jan 25, 2010
  • 35 Answers
SOURCE: I have a thermostat mixer shower but hot water has
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Posted on Feb 19, 2010
Why does the water temp delivered from two Visu-temp valves in back to back bathrooms turn lukewarm after about 4 minutes.
personally I would change the temp setting to hotter water .isn't that why we have a cold water valve also to mix you will use less hot in the long run
Jan 15, 2015 | Water Water Heaters
Why does the water temp, delivered from two Visu-temp valves in back to back bathrooms, turn lukewarm in less than 5 minutes.
check the inlet tubes in the water heater suspect you will find it broke near the top of tank
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
My gas shower is either luke warm or very hot whats wrong
If all the other faucets work, then the problem is the mixing valve in your shower. You will need a new shower fixture.
Apr 10, 2012 | Bosch Water Heaters
Rinnai Infinity 26 hot water system set to 55 degrees with remote temp adjuster. Water only luke warm for showers. Burnner working, water & gas pressure ok. Any thoughts ... Stephen
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
Jul 09, 2010 | Rinnai Digital Remote Water Heater Control...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
The temperature in my shower is very luke warm only at the shower
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Logo
52 people viewed this question
Top Grohe Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
