I am having 21inch CRT BPL color TV. when i switched it on channel is coming and its automatically tuning and only grain are coming.. (means missing channel) I tried auto tuning,semi autotuning and manual tuning its not working. But Fine tuning is working until i stick to one channel. howerver if i change the channel , same problem occur.. Please help me in this regards
  • 5 more comments
  • sinu Jan 09, 2013
    is main system memory IC is costly?
  • sinu Mar 01, 2013
    is it enough to say main system memory IC for tv to electronic shop.?
  • sinu May 23, 2013
    hello sir, I am having 21inch CRT BPL color TV. model Number is FQR21. We given Tv for repair and the problem was Channel shifting.Now the problem is none of the channel is coming, i have done tuning also but in vain.But if i Put DVD player in tv Input then TV is working.What would be reason and give me the solution also. please reply ASAP..
  • sinu Jul 02, 2013
    Sir , as per your instruction i change IC serial number 24C04, but of no use. still the problem persist. At last I shown to Service engineer he told that the Main IC gone and its not available in market. Better to change the board . Is he telling correct? What to do help me.
  • sinu Jul 04, 2013
    one more question sir.. My 14 " philip color TV,When i switch it ON, few line are coming on top of the screen . it is not color line. but after 5 minute it will go. what would be the reason
  • sinu Jul 20, 2013
    14 inch TV, picture coming with black strip down the screen....and brightness is not working...why
  • sinu May 26, 2014
    hello sir need help. I replace IC 2404c but the mention probem exist as it is.they are telling to change Main board...cant able to see how many channel are coming. can i use set top box since we are giving input to av . and tuning is happening in Set top box.
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Check and replace its main system memory IC. It is faulty.
I am having 21inch CRT BPL color TV. when i switch - 1_9_2013_2_41_11_am.jpg
Posted on Jan 09, 2013
Testimonial: "My 14 " philip color TV,When i switch it ON, few line are coming on top of the screen . it is not color line. but after 5 minute it will go. what would be the reason"
  • 6 more comments
  • sinu Jan 09, 2013
    Is main system memory IC is costly.. is there any problem in Tuner?
  • The Knight
    The Knight Jan 09, 2013
    No. It is a cheap to buy, and easily available at most of the electronic spar part shops
  • sinu Feb 27, 2013
    sir can you tell me the IC number as the picture you had given, is not veiwable
  • The Knight
    The Knight Mar 01, 2013
    No. It is cheap to buy. Is a very small IC, having only 8 solder terminals. Even though its physical size is very small, the function of it, when the set works is great.
  • The Knight
    The Knight Mar 02, 2013
    No. The IC will have a number printed on it. You should give that number to them. It usually starts with somewhat 24C XX.
  • The Knight
    The Knight May 23, 2013
    Hello The memory IC [shown before] must be defective. This IC is responsible to store the tuning voltage data to different stations. Even though it looks small, its function when set is switched ON is great. Replace it with same number used in your TV. OK?
  • The Knight
    The Knight Jul 04, 2013
    These few lines, that are seen across the screen's top part, is due to a vertical deflection out problem. Probably, a voltage smoothing problem to vertical output IC. Replace the supply filter capacitor to vertical IC's input supply. It will be best to replace all the electrolytic capacitors at the vertical output section circuit. 5 or 6 of them will be there. Change all with same capacitance value. Just replace the supply filter capacitor. It must make the set to work properly.
  • sinu May 26, 2014
SOURCE: Child lock in a Koryo TV 21inch.
Go to the channel where Child Lock is ON
Press " --- " Key ( below channel 9 button) for few seconds,
Child Lock will be OFF
Press again Tune Lock will be OFF.
Posted on Jul 31, 2008
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
SOURCE: How to increase channels on Old BPL TV
hello sir, iam having a BPL tv,with 100 channels,,,the problem is i cnt watch around 50 channels,even the cable operator provides 100 +. there are three bands coming while tuning,L,H and U.am getting channel during L,H,but when it goes to U,then everything is blank...U(UHF) is starting from around 55,so all channels are blank upto 99. could you please help me???
Posted on Apr 27, 2010
SOURCE: how to switch off psm in bpl tv?
first you can take og remote controll,then press and hold power key.this time tv will going off.bt dont relealese power botton of remot...after turn on tv...........tv will psm off.......
dkm kerala
+919447259335
Posted on May 11, 2010
Bpl tv power suply more
Check those capacitors in video chroma section.
Jun 30, 2014 | Sony Televison & Video
Bpl tv problem
www.servicecentreinfo.in/bpl-service-centres-in-india-customer-support
Jun 30, 2014 | Televison & Video
Increas channel capacity in bpl prima tv
BPL Prima has the capacity of 100 programs only. There is no other way to increase its capacity.
google.com/+GopakumarGopalan Gopakumar Gopalan Google
Apr 10, 2014 | Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Black and White Channel
Check the fine tuning for that channel.Adjust + or - accordingly, see what happens?
Oct 02, 2009 | Apex Digital AT2708S 27" TV
Sep 11, 2009 | Televison & Video
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
May 06, 2009 | RCA F32648 32" TV
Mar 28, 2008 | Televison & Video
Some channels missing...
Try to tune the tv in manual search method. If you get means store it manually. Nothing to worry. This is due to malfunction in AUTOMATIC FREQUENCY CONTROL COIL weak. Even you won"t get channels in manual tunning method. Change tuner and afc coil. Problem solved.
Sep 04, 2007 | Mitsubishi CS-27205 TV
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
Electro Med Services...
