Question about Toshiba 50H72 50" Rear Projection Television
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
CAN'T GET THE CONVERGANCE TO LINE UP IN IN LOWER LEFT CORNER, BLUE IT BENDS THE PICTURE IN THE LOWER CORNER
  • 273 Answers
You have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Posted on Jan 20, 2009
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
I have a Sony KP-51ws510 that has wavey or fuzzy corners opposite of one another?
The problems ur tv having it is call a convergence problems,it dead.Very common problems,for old DLP tvs design.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than tv covergence board is dead.Tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Sony KP-51WS510 51" Rear Projection...
The blue lines on the left lower side of the tv will not converge. The tv has never given me a problem. I woke up one morning and powered it on and noticed the blue is misaligned. I tried converging and...
This problems can happen to the DLP tv any times of it tv life.Tv is 100% have a convergence problems.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Pioneer SD-643HD5 64" Rear Projection...
The lower left corner of the picture has a red out of line convergence. It will not adjust. what can I do?
The tv have convergence problems is dead.The tv convergence board require 2 STK convergence ICS and some or all it resistors changing.To solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 14, 2010 | Toshiba TZ50V51 50" Rear Projection...
Ghost image arcs over picture
This tv have a convergence problems,it dead.The covergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be replaced to solved covergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Philips Magnavox 51MP392H Rear Projection...
Philips Blue Shadowing
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Sep 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sony KP53S35 blue projector problem
You need to replace both convergence ICs. They are STK392-110 they are located on the g Board on big heat sinks designated as IC809 and IC810. You can get new replacement ICs at the following link and they provide free unstalation instructions with pictures plus free on line tech support. here is the link. If you cant access the site right away try again cause they get super busy in the evening with customers placing orders.
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Sony KP-53S25 53" Rear Projection...
Blurred picture
Sounds like a resistor in the convergence circuits or covergence amp ICs them selves. Usually the ICs will distort the picture. My guess would be the flame proof resistors near the ICs 1 or 2 may be oen. Let me know if you need anything further.
Jan 26, 2008 | Toshiba 61HX70 61" Rear Projection...
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
