Question about OCE Office Equipment & Supplies
Getting a malfunction code c-0096 on my oce printer
Cm 3520 model number
  • OCE Master
  • 1,297 Answers
The error code refer Transfer belt separation.Check the transfer belt unit.
Posted on Feb 05, 2013
4 Suggested Answers
SOURCE: Oce TDS 400 Printer. Erore Prob.
erore
Posted on Aug 25, 2008
voodoomox
  • 1689 Answers
SOURCE: Malfunction detected C-0096
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Posted on Aug 14, 2009
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Im getting an error code 08519
Error codes can change depending on the model number. Please ensure that you give the model number of your printer to get the proper answer.
Mar 05, 2014 | OCE Office Equipment & Supplies
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Copier says malfunction detected code C-0096
this is the error code for the image transfer belt pressure retraction failure to reset error code with the machine turned on open and close the front door if error comes back will have to replace either the transfer belt or the belt pressure motor
Oct 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
What is error code 06112 ?
oce is a variety of different model of copier send me the picture of your copier then i can tell what model is it and what is the real problem low_toner@yahoo.com
Aug 06, 2009 | OCE Office Equipment & Supplies
Jul 13, 2009 | OCE Office Equipment & Supplies
Oce 3121 coping machine make random black line shadows
if you are getting copy quality issues on all aspects of the machine, IE, printing, copying, ADF, it looks like then you might need a new drum installed. please contact your local service department for service and make sure if you need supplies, to have those on hand before calling a tech to come service the machine. drums, developers, and toner are considered a supply item and are NOT carried by technicians unless otherwise stated in your local contract.
Jun 23, 2009 | OCE Office Equipment & Supplies
Oce 3165 Copier makes black copy over text.
that is a very expensive and big machine. as an oce representative i suggest you call it in for service.
Oct 27, 2008 | OCE 3140 Copier
130 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
