Question about Maytag MMV5207A Microwave Oven
The timer doesn't work right.
When i set it for 2 minutes it runs for 2 seconds.
  • Maytag Master
  • 9,098 Answers
Are you programming it for 2:00 or just pressing 2, then Start?
Try resetting it by unplugging it for a couple of minutes, plugging it back in, then setting the clock and trying again.
Posted on Jan 09, 2013
Timer runs 10 times speed
Try to power by locating circuit breaker that powers that area?
Nov 05, 2012 | KitchenAid KCMS2055SSS Microwave Oven
How do I tighten the Timer Knob on my Whirlpool AVM 950 Microwave Cooker Hood Combo?
Look to see if a flat nut under the knob or a Allen nut/bolt that secures the knob is loose--some are drilled into the side of the knob.
Jun 14, 2012 | Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
Hi when i set the microwave at 100 watts for 1 min it starts and stops working by itself when timer reaches 38 sec and it also dosent make the beeping sound in the end.please help
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
Aug 31, 2011 | Bosch HMT9656GB Microwave Oven
Timer runs super fast, I dont think its heating at all. set for one hour, takes only a few seconds to run. Owned since 2003
I have a Maytag that did the same thing. I unplugged it for about 2 minutes, plugged it back in and it is working fine.
Nov 30, 2010 | Kenmore 62342 Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Clock will run down to 1 second of the minute and microwave will stop
The surge probably didn't cause this. This common error indicates a problem in the convection damper circuit. It may be a defective damper switch, damper motor, or a jammed damper door. I have attached a drawing of a typical damper system. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Sep 21, 2007 | Dacor PCOR30 Convection/Microwave Oven
Maytag MMV5207A Microwave Oven Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
