I have a paper shredder that will not shread paper. The rollers move front and backward, but it makes a nosie like something is off track.
  • 3,904 Answers
Your only choice is to take it apart and see where it has been dislodged from its proper position.
Posted on Jan 09, 2013
SOURCE: CHAMPION PAPER SHREDDER
My champion shredder had too many papers go thru because I didn't see the enclosure in one of the flyers. the shredder has now stopped. I have tried to pull the paper out but I reverse the wheel and now the paper is stuck behind the the wheel where I can reach. The motor is now ona humming sound. Are there screws on either end that I can remove the top? Please give advise n what to do. This is not and old shredder.
Posted on Apr 30, 2010
SOURCE: Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Posted on Mar 05, 2009
SOURCE: Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Posted on Jun 14, 2008
SOURCE: Shreder will only go backwards
I have a Fellows OS-11Cs shredder that suddenly quit operating. It would run in reverse and when auto mode was selected an audible clicking noise was emitting from a relay on the pc board. My initial thought was that I had overheated the unit since the shredder had been operating perfectly up to the point where it stopped working but that didn't seem to be the case after the unit was allowed to cool down.I cleaned all visible paper shreds from the cutters(with the shredder unplugged)that were visible and then sprayed the cutters with a very light lubricant (3 in 1 oil) I then operated the shredder in the reverse mode for a few moments and since then the shredder has operated flawlessly.I hope this is of some assistance to others with a similar problem.
Posted on Sep 29, 2008
JayBlair
  • 328 Answers
SOURCE: Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jan 12, 2009
I have paper stuck in the top of my shredder, How do I remove It?
This happens more tomes than I can count with my mom. You cant feed an feed it an not stop an clean out the shreads that build up in the teeth. You will need to remove the top or how ever you can get it apart. Get what ever tool you can find an begin clearing all the paper from the teeth or rollers. You will notice a switch on the side that gets jammed at times an stops the unit. Also if it got to hot you can reverse it an the paper will back out. They quit from heat, to thick or many sheets at once, an paper jams. I used a pencil an a paper clip once. Use what ever it takes.
Jan 29, 2015 | Office Equipment & Supplies
Paper shredder doesn't move due to too much adhesive paper - how to fix it
Before trying anything I suggest, make sure your shredder isn't plugged in.
You will need to remove the adhesive from the rollers. You will need to use a glue solvent on the shredder rollers,something like Goo Be Gone. Personally, I still use Ronsonol Lighter Fluid In the image below I've outlined the supplies you'll need to, hopefully, clear your jam.
25346531-f3timxio4jyou4u0bydnlgfi-2-0.jpg Without disassembling your shredder, the best way to clear your jam is to use Rosonol Lighter Fluid (3), tweezers (4), and dental picks (5).
  1. Make sure you are working in a well ventilated area. Separate the shredder from its shredded paper collection tub.
  2. Turn the shredder head upside down so that the paper output is facing up.
  3. Pour Rosonol lighter fluid on both sides of the rollers near where they come together.
  4. Use dental picks and tweezers to dislodge stuck paper pieces
  5. Turn Shredder head over and repeat steps 3 and 4
  6. Move power switch to the "Off" position
  7. Plug power cable back in
  8. Move power switch to "Rev" (reverse) position, if still stuck move power switch to the "Fwd" position, repeat twice
  9. Repeat steps 1 - 8 until the rollers move freely
Once the rollers are moving smoothly you need to oil the rollers.
Dec 30, 2014 | Shredder Office Equipment & Supplies
How do I clear the paper clog from the rollers?
First try to run it backwards. Sometimes that will clear a clog. If not UNPLUG IT, and painstakingly pick out any paper lumps with tweezers, slowly. GOOD LUCK! I have spent a few hours in front of the TV just picking out paper bits. In the future, be sure not to put in more than two or three pieces of paper at a time, NO STAPLES, and use shredder oil ever fifty or so sheets you put through!!!
Aug 20, 2014 | Cross Sentinel 10 Sheet Cut Shredder
Shredder keeps running on auto
Unplug it and check to see if theree is any paper caught in the Start switch. Turn it Off, plug it back in and start in the Reverse mode. Then turn it Off and set the swich for On - shread.
If that doesn't work unplug it and find the start switch trip wire, Toggle it a few times with something thin - don't push too hard. You can also spray the switch the canned air used to clean keyboards. Plug it back n, start it in reverse then move it to shread.
Jun 19, 2014 | Omnitech 18-Sheet Cross-Cut Shredder
I have an Ativa 1850. When putting papers in to shred the papers move to the right side and bunches up the paper. The shredder now doesn't want to work properly. No papers will go through to be...
You probably need to get some shredder oil and lubricate the cutter heads. see: http://www.walmart.com/ip/Fellowes-Powershred-Shredder-Lubricant-Oil/8207323
Apr 19, 2011 | Office Depot Ativa 1850 (MicroCut)...
Ht500 shredder
check the cutter slot, there should have a micro switch with a level, that detect the paper when the paper is in the slot.
the micro switch may be dirty or some thing is preventing it from starting.
Jan 07, 2009 | Adler Royal HT500X Shredder
Oct 20, 2008 | Office Equipment & Supplies
Sep 06, 2008 | Fellowes Powershred 480 Shredder
Jun 13, 2008 | Fellowes PS70-2CD Shredder
1,082 people viewed this question
k24674
jasbo
jasbo
