Question about Miele Cat & Dog 326i Bagged Canister Vacuum
My Miele Cat and Dog has stopped working. There was a slight burning smell and then it switched off completely. Also, the bag was a bit wet, so have replaced with a fresh one but still not working. Help!
SOURCE: Miele Cat & Dog Vacuum
I have a Miele White Star. The Turbo Plus attachment has stopped working. Brush will not turn. I've had it all apart and cleaned it. Still a no go. Is there an electrical connection somewhere. Fixable or should I just replace it? Thanks Mary
Posted on May 23, 2007
  • 883 Answers
SOURCE: miele .s5210 Bag Vacuum
either the switch or the motor has burned out. try resistance test on each. look for positive resistance change on switch and about 2 ohms on motor. also look for a disconnected wire
Posted on May 26, 2007
reddevil6
  • 1673 Answers
SOURCE: stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Posted on Jan 17, 2008
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
  • 195 Answers
SOURCE: Reset light is on.
set big Cat to stay on porch. (Smile)
Posted on Dec 07, 2008
Using hoover, stopped working. Bag very full so changed. Hoover seems very hot. Will not work. Checked fuse
Give the vacuum time to coold\ down, then try again. If it still doesn't work, take it to a repair shop to be checked.
When a vacuum is used for long after the bag is full, the motor can overheat to the extent that the motor burns out. This is one of the benefits of having a vacuum that shuts off when the bag is full.
You should also check the hose for clogs. Disconnect at both ends and drop a coin in one end. If it fails to fall through, there's a clog that needs removed. This is likely to happen at the canister end when the bag gets too full.
Apr 04, 2011 | Miele Cat & Dog 326i Bagged Canister...
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Changin the dust bag how do you do it?
1. open the bag compartment by lifting the black catch near the handle. 2. grip the grey plastic fitting on the bag, using the little handles on each side, and slide it out of the black holder. As you do this, part of the grey fitting remains caught in the black holder, and this causes the bag closure to cover the hole. When the cover is fully in place, if the grey bit doesn't release itself, you can help by slightly lifting the black tab where it's trapped. 3. slide the new bag in where the old one came out, and close the lid. 4. job done!
Jun 07, 2009 | Miele Cat & Dog 326i Bagged Canister...
Reset light is on.
Dec 07, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele cannister power up problem
8 identical screws holding the cover on. The control panel at the back has a screw and 2 push in clips. It lifts off and unclips the power.
May 21, 2008 | Miele Cat & Dog 326i Bagged Canister...
My Miele cat & dog
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Stopped working - warning light on
Dec 05, 2007 | Miele CatAndDog700 Bagged Canister Vacuum
doubt it. could be dangerous to use. (had one burn up due to this)
Apr 23, 2007 | Miele Cat & Dog 326i Bagged Canister...
Miele Cat & Dog 326i Bagged Canister Vacuum Logo
59 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
