Question about Staples SPL770M Shredder
Makes noise, will not shread anything
The rollers roll forward and backward, but it makes a terrible noise like something is off track. I cleaned it out and oiled the rollers, but it still wont shread.
My 2001 Nissan Altima driver's side seat has all motion except backwards. How can I get it to go backwards?
the backward motor has quit working, go to junk yard and find same car in your year range up or down pay particular attention to how your seat track looks. designs change every three or four years. it must be exact or it will not work.
Mar 31, 2015 | 2001 Nissan Altima
Riccar supralite makes a loud rattling noise like the roller is banging around
If the noise is not something in the brush roll or the brush roll bearings or shaft is damaged the impeller may have something stuck in it or it may be broken.
May 15, 2014 | Riccar Vacuums
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Makes a terrible squealing problem but still heats
Remove the drum.
Inspect the drum seal,rear rollers,tension roller,front drum glides.
It could be any one of these bad or a combination of theses.
May 25, 2009 | Dryers
Noise
More than likely the rollers under the glass tray have build up on them. simply remove tray and rollers and clean rollers with soap and water.Before installing clean track area that rollers set in and should run smooth after that. If this doesn't do it then reply with more info about it < does tray move in a jerking motion?, does unit have circular cover in the top? in right upper corner there is perferated metal,is it discolored?> should be able to figure it out if it isn't rollers.
Apr 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My 2001 oldsmobile intrigue will roll backwards fine, but when i go forward the front wheels shudder like something is rubbing. I checked brakes and they are fine.
Try turning the steering completely left and drive forward. See if the car feels like it catches or makes a crunching sound, do the same by turning all the way to the right and check for crunching or snapping noises. If it does, check the axle shafts, the CV joints are more than likely worn out.
Let me know.
REgards,
Mar 05, 2009 | 2001 Oldsmobile Intrigue
Noise from HP LJ 1020
Change the gears , coz when the machine load or when you are printing the roller turn, and those roller has gears at the ends so when they are died they give those sounds, open the cover and try to detect which gear make this noise and change it.
Mar 01, 2009 | HP LaserJet 1020 Printer
Drive shaft noise
when i back it up or move it forward when it is in nutral,, i cant hear it when the bike is running nor can i feel it when im ridding only when the bike is off and i roll it forward or backwards any ideas on whats wrong?,check the final drive lube level, make sure that's good. if that's ok then the problem probably is a worn worm gear that only makes noise when its moving slowly. To make sure its the drive and not tranny itself, see if it makes the same noise in 1st with the clutch in rolling it around. ,,,
Nov 10, 2008 | 1983 Laverda Alpino 500
Staples SPL770M Shredder Logo
57 people viewed this question
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
