Question about Singer 3343 Mechanical Sewing Machine
I have the Singer 3343C When I sew across the fabric the stiches do not catch so the to pieces are not sewn together.
I've had this to happen if I have the bobbin in backwards.
Posted on Oct 23, 2013
  • 1116 Answers
SOURCE: Sewing on reverse of fabric
There has to be thread on both sides of the cloth in order to form a stitch.
Refer to the maintenance section of your machine and clean the machine as recommended.
Did you change the thread or needle?
Check the manual to be sure the threading is correct and was done with the presser foot up.
Is the needle is correctly installed?
Check the bobbin to be sure the thread is feeding in the correct direction and through the guides on the side of the bobbin case.
Posted on Apr 29, 2010
SOURCE: i have a singer 140
does the bibbin have thread and in correctly?
Posted on Nov 29, 2010
SOURCE: I have a singer 3343c
the presser foot only holds the fabric against the feed dogs in the needle plate area
check the feed dogs to see if there in the up position
if not there should be a nob in the feed dog area to move them up & down
on some models when you remove the extension table the nob is at the back
Posted on Dec 10, 2010
  • 980 Answers
SOURCE: my singer sewing machine is
try a new needle first if this fails you may need to have the machine retimed
Posted on Sep 02, 2011
Joe Onley
  • 363 Answers
SOURCE: Singer Electronic Control Sewing Machine
Hi Cat,
This seems to be a common problem, but easy to fix. Check the bobbin, and see if the thread feeds out quickly when holding the thread and letting the bobbin case drop. You should see a small screw on the front of the bobbin case for adjustment. Screw that until the drop rate is slight. You may need to adjust a few times to get just the right rate of feed.
Hope this helps, Please rate and comment, Thank You
Joe
Posted on Sep 07, 2011
My singer 4830C sewing machine won't make stitches. It runs the thread across the fabric but isn't catching
Clean the bottom. The place that nail going into it. You can use Vaccume too.
Dec 15, 2013 | Singer 4830
Help Singer 3343C wont zig zag?
You need a zigzag attachement, you can get this at any fabric store.
Aug 28, 2013 | Singer 3343 Mechanical Sewing Machine
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
Singer sewing machine 3343c isn't stiching
Sounds like your machine is out of time. Take it in for clean, adjust and timing.
Sep 02, 2012 | Singer 3343 Mechanical Sewing Machine
Ihave a Singer Curvy 8770, needles keeping breaking and it's not stiching. I am just tring to stich basic frabic together
I would call Singer because something is not in alignment if your have checked all of the suggestions that your manual gives. Without seeing it, I don't know how anyone can help because we cannot see what the needle is hitting, it is like working in a dark room. Singer's phone # 1-800-4singer, JoAnn Fabrics usually has nice people who are very helpful and I know that they sold this model at my JoAnn's because I bought one for Xmas for my granddaughter. They probably will spot the problem right away
Apr 24, 2011 | Singer Curvy 8770 Electronic Sewing...
I have a singer 3343c machine, when sewing the fabric foot does not move, the fabric while the machine is sewing.
Dec 10, 2010 | Singer 3343 Mechanical Sewing Machine
Skips stiches
This is normally a needle related problem, change the needle for the type of fabric to be sewn. If it is a stretchy fabric, get a "stretch" needle.
Good Luck
Oct 18, 2010 | Kenmore 744-08BH Mechanical Sewing Machine
Singer 3343 Mechanical Sewing Machine Logo
540 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
