Question about Frigidaire PLMV168 Microwave Oven
Lite bulb broke.
Bulb broke in socket
  • Frigidaire Master
  • 9,047 Answers
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Posted on Jan 09, 2013
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Cooktop light socket needs replacing, bulb broke in it. Socket needs replacing.
make sure the light is off, better yet turn off the breaker
take a potato a little larger than the socket, cut it to size, whatever.. jam it into the broken bulb (carefully), this will allow you to grip the broken bulb safely. turn counter clockwise and whats left of the bulb should unscrew out.. works VERY well
Feb 15, 2013 | Microwave Ovens
WE have a GE Spacesaver Microwave installed July 2005. I have tried to replace burned out nite lite bulb. Both bulbs broke from socket as I tried to unscrew. Bulb base will not unscrew. How do I get the...
First be sure the oven is unplugged whenever you are removing or installing light bulbs.
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
Once you get new bulbs in, if they don't work, that's circuit board damage which we repair for $39.95 for customers nationwide and you can feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 01, 2008 | Microwave Ovens
Broken bulb
From what others have said, it will come out, but you have to use some strong good needle nose pliers to turn the base in the socket.
Jan 12, 2008 | Whirlpool MH2155XP Microwave Oven
Broken bulb
Get yourself a cork from a bottle of wine (wait to drink the wine until after you've removed the bulb!). Now, with the power plug REMOVED from the wall socket, gently but firmly press the cork into the broken bulb. You should now be able to screw the broken bulb out of the socket. If there's not any bulb glass or shards or anything else for the cork to grip, you may need to insert a small pair of pliers into the socket, and with reverse pressure (i.e. pulling the handle apart as opposed to squeezing together) you may be able to remove the bulb. And if that doesn't work, well, keep trying. You just need to be creative. Try using needle nose pliers and grabbing the edge of the bulb socket and gently work to loosen (remember lefty loosy, righty tighty) turning counterclockwise to remove.
Dec 30, 2007 | Kenmore 62702 Microwave Oven
On replacing nite-lite/under hood bulb, 1 lead broke off in the socket
Be sure to disconnect the oven from the power line before removing or installing bulbs or working on it. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 22, 2007 | GE JVM1490 Convection/Microwave Oven
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 21, 2007 | GE JVM1430 Microwave Oven
Which bulb do I need for Samsung MW6573G microwave
You can see a photo of it here: http://www.samsungparts.com/images/parts/tv/4713-001012.jpg It's an assembly, and not meant to be separated. But if you have a clean socket, you can use a standard 40W appliance bulb that will fit it. Otherwise, you can get the original bulb assembly at that same site if you prefer. It's part # 4713-001012.
Dec 13, 2006 | Samsung MW6572W/MW6573G Microwave Oven
Frigidaire PLMV168 Microwave Oven Logo
216 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
