Question about Majestic MCR9141HP
No sound After doing some work on my dash, that involved serious jiggling and moving of my Majestic mcr 9141hp, it no longer has sound from the radio or tape. On the tape, if it's turned up to full volume, there is a faint bit of sound. Power comes on, electric ant. goes up, but no clock or radio display.
Remove the unit and check the integrity of your connections.
Posted on Jul 06, 2007
JVC KD-SX990 Stereo randomly off and on
If you've confirmed that it's actually losing power (a CD will start over when the display and sound come back) instead of just the display cutting out, then you should first check your fuse panel in the vehicle, and make sure the fuse that provides power to your radio is seated firmly and securely. Try jiggling it if you can and see if the radio cuts out then. If it seems fine, take the radio out of the dash but leave it connected. While it's powered on and playing, jiggle the connector that's plugged into the back of it. If it's still fine, do the same thing with the wiring harness that's connected to the factory wiring. At one of those connection points (fuse panel, connector at rear of radio, or connection to the factory wiring in dash) you may have a loose connection.
If you cannot repeat the radio failure by doing this, you likely have an internal problem, such as a failing power supply, or it's overheating and shutting itself off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Sep 14, 2017 | JVC Computers & Internet
My 1946 majestic radio/record player has a loud hum. How do I get rid of it?
Hi Leslie:
If that is not a typo and you really have a 1946 radio/record player, it will probably have tubes and one or more may be no longer working properly.
You may be able to get rid of the hum by changing tubes.
You can probably get rid of the radio.record player by advertising it under collectible electronics.
Cheerfuls.
Apr 11, 2016 | Televison & Video
Radio appears not to work at all. No sound.
check to see if you have 12 volts at the memory (yellow in most cases) wire it should be powered all the time the red wire is acc. key on
Jan 17, 2014 | Yamaha MCR-042 Micro Component System...
My radio just has white noise sound and no stations are coming in but rarely i can get one signal to come in but not long does anyone know the problem
Most likely your antennae cord has jiggled loose from the the jack on the back of your radio. If it's not something you can see from underneath the dash, you'll have to pull the radio to be able to plug it back in. If you do have a view of your radio from underneath the dash, look for a loose wire (typically black, about the size of a coaxial cable, with a silver tip on the end.) There's a hole in the back of the radio where that needs to be reinserted.
Oct 20, 2013 | 2002 Dodge Durango
Truck won't start unless i jiggle wires under dash.
I doubt it unless you are moving the wires coming out of the switch.
Sounds like a bad connection or broken wire in the harness you are moving around.
It could involve the neutral safety switch and the harness you are moving could come from that switch.
Jan 11, 2013 | Cars & Trucks
My CD & radio just stopped working. The screen still displays everthing and the CD track changes just no sound.
This is usually an internal failure with the head unit (the radio box in the dash) usually getting a new head unit will solve the issue, however it could be as simple as a broken or disconnected connector. Try getting to the back of your radio and inspect the connectors. Also try jiggling the wires to see if its a loose/sloppy connection. Either way, you're going to have to pull apart the dash. In some rare cases, the vehicle will have an external amplifier, if this amp popped a fuse or had some internal fault, that would cause the radio to show everything, but have no sound. Check you fuses first, especially anything related to "Audio", "Instrument", "Dash", or "Amp"
Nov 17, 2012 | 2009 Pontiac G6 GT
I have a 2002 Chevy Malibu. The dashboard lights are off including the radio. However when I jiggle the dimmer switch, the dash lights would come on. Now whenever the sensor puts my regular lights on,...
I am not sure if I can help but have you tryed replaceing the dimmer switch or checking the connection to the dimmer you should be able to bypass the dimmer and the dash lights should come on bright also are you talking about the dimmer on the dash or the headlight dimmer I am thinking you mean the dimmer on the dash
Sep 14, 2011 | 2002 Chevrolet Malibu
My filter queen majestic quit working. I opened up the unit to see what was wrong and I did not immediately notice anything wrong. Upon furter examination I noticed one of the traces on the printed circuit...
I recommend replacing the card. Soldering involves the risk of further damaging the card, so it would be useless anyway. Why waste valuable time?
There is a possibility of the motor overheating, generally due to a blockage in the airflow system somewhere. Check all filters, hose, wands, and power nozzle for dirt and/or clogs.
Check wiring connections, including hose to wands to power nozzle. Check all switches.
It sounds like you know how to do this, but if you have any questions, repost.
Jan 03, 2011 | Filter Queen Majestic Canister Vacuum
Hi there my cable that opens door snapped so i
IT SOUNDS LIKE YOU HAVE AN ELECTRICAL SHORT.TURN ON THE IGNITION SWITCH ,OPERATE THE WINDOW SWITCH WHILE JIGGLING ALL WIRES INVOLVED. IF WINDOW BEGINS TO MOVE REPAIR OR REPLACE CONNECTION THAT WAS BEING MOVED WHEN WINDOW BEGAN TO MOVE
Jun 10, 2009 | 1998 Jaguar XK8
Car Audio & Video Logo
59 people viewed this question
Top Majestic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Majestic Car Audio and Video Expert? Answer questions, earn points and help others
