Question about Dell Xps 15 Laptop Computer (Intel CORE I5 500GB/6GB) (dndoge1) PC Notebook
Dell xps 15 error 2000-0146 locks on dell startup screen have to do hard boot ran 64 bit diag, read failed. I had just transferred around 2 years worth of pictures to one location (hard drive) when th
I read a lot of good reviews on this cable, amazon mailed it, but i never received we are leaving on vacation soon, so I am under a deadline and would love to have some sort of resution. dell really didnt care about my pictures. i know dell used to void the warranty if you even opened the machine, but they just want to replace the drive and told me that data retrieval wasnt possibl e. this cable reviewed gave me hope as i do have anothrr 64 bit inspiron win7 laptop. to connect to. any help is appreciated. sorry for the typing i am using my kindle thks
    Diehard:
    Visited the website for 60 consecutive days.
  • Dell Master
  • 646 Answers
With os disk in dvd drive. try system repair, You can do this by tapping rapidly on the F12 key at the Dell Splash screen when the system starts up and choose the CD/DVD drive from the Boot Once Menu that appears. You can tap rapidly on the F8 key when the System starts up and select the repair your computer if it works and windows boots transfer pictures to another computer. only run the bad hard drive for a long as needed to get recover your pictures
Posted on May 01, 2017
  • 70 Answers
SOURCE: dell inspiron 9400 dvd/cd rom not recongized.
I'm a Help Desk Support/PC Tech (and the ONLY one for my company) so I live and breathe all kinds of issues...it's my bread & butter. I recently had a co-worker bring a laptop to me for the same reason...not to say that you're having the same problem but with what information you did provide, it does sound quite the same. The DVD wasn't listed in Device Manager nor My Computer and it wouldn't play any discs. The operating system installed on his laptop was Windows XP but the fix is the same for both XP and Vista.
I finally came to the conclusion that the cause of this problem was due to corrupt registry entries, possibly left by CD burning software. He had installed iTunes for his iPhone and the previous user had also installed a CD burning program. And, there's no telling what else had been done to the system. Sometimes removing an installed CD burning program can cause these corrupt registry entries to interfere with the functionality of your DVD/CD drive. If this is the problem, the fix is as simple as making as checking the registry to see if the entries are there and making as much as a couple of changes in the registry and viola! It works again.
ALWAYS CREATE A FULL BACKUP WHEN MAKING ANY CHANGES TO YOUR SYSTEM. When modifying the registry, you can also create a backup of the registry only and restore it from the backup if any issues occur.
Try this for Vista:
1. Click Start then click All Programs
2. Click Accessories then click Run
3. Type regedit into the text box then click OK
4. In the navigation pane,on the left, locate HKEY_LOCAL_MACHINE then click the folder to open it and find the SYSTEM folder. Click the SYSTEM folder then go to the folder named CurrentControlSet and click it. Drill down to the folder named Class then click it. Within the Class folder, you will see several folders named with a series of alphanumeric characters enclosed in {} brackets. Find the one labeled {4D36E965-E325-11CE-BFC1-08002BE10318} and click it.
5. If I'm correct about your problem, in the right pane of the window, you will see UpperFilters (if not, your issue is caused by something else and you can exit the registry). If you do see UpperFilters listed in the right pane then click it.
You may see an UpperFilters.bak registry entry. You do not have to remove it. Click UpperFilters only. If you do not see UpperFilters but do see LowerFilters, you still may have to remove that entry for this fix to be successful.
6. On the Edit menu, click Delete. You can also right-click UpperFilters then click Delete. Confirm the deletion.
7. Now for the LowerFilters, in the right pane, click LowerFilters (again if you DO NOT see this entry nor did you find the UpperFilters entry in the registry, you will need to move onto troubleshoot further).
8. On the Edit menu, click Delete. You can also right-click LowerFilters and click Delete. Confirm the deletion.
9. Now you're finished. Exit the Registry Editor and restart the computer.
After you restart your computer, the first thing that you should do is open My Computer to see if the drive is now listed. If you did find the Upper and LowerFilter entries in your registry and removed them, your drive should appear now.
I am assuming that your drive is still operable and is installed correctly. When I fixed this same issue on my co-workers laptop, the DVD ROM was recognized and working after the reboot. Also, because these registry issues are one of the most likely causes, it doesn't hurt to go into the registry just to see if those entries are there. If they are present, this is most likely the cause and the only solution that I know of.
Try these steps if you haven't already and post the results...
Posted on Mar 26, 2009
efs_perpends
  • 1996 Answers
SOURCE: Can my hard drive be salvaged?
You can definitely get another one, as long as it's compatible with your system...get the original specs from dell, then search online at western digital, tiger direct, etc. etc.Many online sites will have recommendations for your system.
Please consult links here and here
You may want to run chkdsk to see what's up with it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 04, 2009
proton77
  • 1183 Answers
SOURCE: Dell Inspiron 6000 laptop won't boot up
Pleae reboot your system and when you see the Dell logo , press the F12 key a couple of times .
In the menu, select only HDD diagnostics and post the results back . If the harddrive fails, then the only solution would be to replace the same. If the hardrive passes , we may be able tp fix the system
Thanks
proton
Posted on May 31, 2009
SOURCE: Error code 2000-0146 in device Hard Drive 1
I just had this same problem a few weeks ago. This error code means you have a bad sector in your hard drive which is cheap and easy to fix. You just need to unscrew the bottom screws holding your hard drive in and place the old cover on the new hard drive you buy. Screw that new one in and reload your programs. Your computer will be as good as knew after that. Look on your invoice to get the hard drive specs so you can buy a new one or just enter your service tag on the dell site and check out the specs of the ones they offer for upgrade.
Posted on Jul 31, 2009
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
Alert. previous attempts at booting this systemhave failed at checkpoint [0032]
XPS 8500 Desktop booting fails - General Hardware - Desktop - Dell ...
en.community.dell.com/support-forums/desktop/f/3514/.../19452875
Dell
Jun 13, 2012 - 16 posts - ‎9 authors
I am sorry to know the concern with the computer. As you .... I have the identical problem on a 3 week old XPS 8500 desktop machine. It seems ... Dell XPS 8500 - Will Not Boot At All - Motherboard ...
Aug 13, 2014
Dell XPS 8500 Unable To Boot
Jun 25, 2013
New Dell XPS 8500 won't boot
Dec 5, 2012
XPS 8500 UEFI boot
Oct 29, 2012
More results from en.community.dell.com
How to Use and Troubleshoot the XPS 8500 ' Dell US
Dec 15, 2015 | Dell XPS 8500 Desktop Computer; Intel Core...
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Windows 7 dell inspiron 1546 error code 2000-0146
HDD Read error, boot to the 32 bit Dell Diags, Custom, HDD, run the diag there. If you get a 0F00:xxxx error in the 32 bit diags then replace the HDD
Jul 23, 2011 | Dell Inspiron17 Notebook 22GHz 500GB 173...
Hi My Dell XPS 1530 Screen remains black at startup
hi
if your Laptop is on and your not getting screen the you have to do two thing
1 remove RAM from the motherboard
2 remove CIMOS battery from the motherboard for 10 to 15 mints
then re fix hope fully your laptop will work
Aug 02, 2010 | Dell XPS M1530 Laptop
I'm getting a stop error code 0X000000ED,0X86714368, 0X0000006, it's on a Dell Latitude D600 laptop?
Unmountable boot volume indicating that the system cannot successfully read the boot sector of the hard drive.
Run the diagnostics on the hard drive, if it fails, replace the hard drive.
If diags pass, boot to the recovery console, run chkdsk /r If it still gives the error after that, you can try reinstalling windows.
If that fails to resolve, then again, replace the hard disk drive
Nov 19, 2009 | Dell Latitude D600 Notebook
Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension XPS PC Desktop
Dell Latitude Dell DVD player
Hi
We will first start with these steps and let me if is still resolved or not.
1. http://support.microsoft.com/default.aspx/kb/929461
Do this step and restart your laptop. Let me know what kind of dvds are you using. Are they movies or with data.
2. Run a 32 bit dell diags on the drive. You can access Dell diagnostics by pressing F12 when you seeing the Dell logo when you start the system. You may have to try couple of times to get to the screen. It will show you one time boot menu. Select diagnostics. Alternatively, if you have Dell diagnostics or drivers cd, insert that and in the one time boot menu select cd dvd and press enter.
It will take you to the diagnostics menu. Select Test my system, then custom diags and then ran a diags on the drive. If they test fails it might be time to replace the drive. If you are in warranty talk to dell tech support and tell them that 32 bit diags on drive failed they will just replace the drive, if not in warranty let me know I will help you in ordering the spare parts online. Drive is not that costly.
3. IF the diags have passed and still having the issue boot system to safe mode and then go to My computer, right click the drive and click on explore. Check if you can see any contents of your dvd. If you can then the culprit is the OS or windows xp then we can do more steps. To access safe mode press F8 when u see the dell logo during start up.
Do share you experience so that I can know how it is working
Thank you
Rakesh
Expert in Dell Laptops.
Jul 29, 2008 | Dell DVD-rom DVD Drive
Dell Xps 15 Laptop Computer (Intel CORE I5 500GB/6GB) (dndoge1) PC Notebook Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
