Question about Panasonic KX-TG9341T Cordless Phone
Phone goes dead in middle of conversation on different hand set battery shows fully charged
It happens most of the time
5 Suggested Answers
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Posted on Aug 11, 2008
SOURCE: battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Posted on Apr 16, 2009
  • 3278 Answers
SOURCE: we have KX-TG 933IT system. when we used the
Hello.
Try resetting your phone (disconnect the power and phone line for 10 minutes and reconnect).
If this occurs with more than one phone on this line, contact your telephone provider to check the line.
Hope this helps.
Posted on Dec 09, 2010
news775
  • 699 Answers
SOURCE: battery very hot never fully charges [1] next
Try replacing the batteries (think they are 2 AAA's in there)
Posted on Feb 28, 2011
Phone keeps cutting out in middle of conversation
You need to ensure that the batteries are fully charged. On the handset while talking, the phone should show how much battery charge is left.
The other thing to check is how far are you from the phone base. For example if your base is on the first floor and you are on the third floor using the handset, then you might loose the signal clarity and eventually loose the connection to the base. To ensure that you are getting enough signal on all the floor, you can purchase a range externder from the manufacturer of your phone.
Dec 17, 2011 | Uniden DECT 6.0 Cordless Phone
Phone goes dead
problem can be solved.Did you download any application from the internet?.If yes, that means the phone memory is dead and it needs to be flashed to restore the memory of the phone back.
You can also check for the battery may be it is not well charged because the cell of the battery might be weak and needs to wake up by much charger.
You can also get another battery to test the phone to be sure it is not the battery.
You can check both the battery and the board to be sure of wish is faulty.
Take care.
May 19, 2010 | Motorola Mobility RAZR V3
What i do when the nokia1600 set is fully dead due to unknown factors?
1. Try recharging the battery.
2. Even after charging the battery for sufficient amount of time, your cell phone goes off in few minutes, you will need to change the battery.
May 15, 2010 | Nokia 6030 Cellular Phone
Lost dial tone
is your unit is new?or your battery is new?if not,then it is probably your battery is weak.you cant say that a battery is GOOD if it still accepting a charge when you are going to charge...let me say that even if a power is stored on it ,you still can't say that it is still good.Becoz when a battery is weak,its current or ampere will become lower than the given specification when it was new.Thus,when a current is low,a batery can no longer supply the exact needs of the unit during the time of conversation,and thats the reason why it will shut down in just almost a minute of conversation even you know that it was fully charged .
Oct 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
In my Samsung B2100 hand set whenever I press the Contacts it says "Entry Empty". Is there any settings should I do in the phone settings?
I just purchased 2 B2100 and both do the same thing. When I receive or place a call I can talk for a short time, less then a minute, then the phone shuts off and shows low battery. When I turn back on the battery is fully charged.This does not happen every time. Both phones have been fully charged
Oct 24, 2009 | Samsung B2100 Cell Phone
Phone shows full battery then goes dead in an hour.
If you turn your phone on the very first time you use it you are suppoesed to charge it for ten hours. or not quite ten but what I do is i charge it all night and turn it off. this way you get sleep and in the morning your phone should be fine. if not reset the settings this should do it.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
Phone goes dead after talking 30 seconds
Try charging the phone. They are usually shipped with a near dead battery.
May 27, 2009 | Uniden Cordless Phone
Battery doesn't last a day
The new battery was missing a little filler piece from the original.  We crafted one which snugged the battery in the holder.  The tolerances are quite tight and the battery needs to be snug.
May 12, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Nov 13, 2008 | Samsung Cell Phones
Panasonic KX-TG9341T Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
