This is rseally tough for some reason. I had to dump my whole computer for uncontrolled virus reasons. I have had my smc wireless adapter for probably a year now and Im am trying to get it working again. I have no disc to go with it, but have had help getting it working once before. Can you please help me. It was done by phone before and seemed to go rather smoothly.
  • 4 Answers
get the manual for your smc wireless adapter manual/drivers here
Posted on Jan 20, 2009
It can not pick up the wireless signal in my house
there are several reason why that might explain it:
  1. if your wireless network is secured, try to remove the security. it is possible your wireless adaptor do not support WPA or WPA2 which I assume you are probably using. try to see if now it connects (with an open network)
  2. do you have another computer that is able to log in? if this is the case, it is possible one computer is set to work with a B network and the other is G. in this case you will need to log into the router using a LAN and force it to work with B (the G will continue to work)
  3. are you sure you are not able to log into the router via wireless connection? could it be that you cannot surf the Internet but you can log into the router? if this is the case, most likely you have a DNS issue. the best would be to contact your ISP support, in most cases they will be able to work with you on setting a fix IP and DNS resolver in your computer
Nov 23, 2010 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
SMCWUSB-G 802.11g adapter will not renew IP address.
you should be able to configure the setting in the utility for the adaptor to auto renew the ip address
Apr 21, 2010 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Adapter drivers needed
Here is a link you will need to sign up for a free account but you can cancel once the driver is down loaded.
Please rate this fixya
May 15, 2009 | SMC Realtec Network Card NERENC01
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Cannot connet to internet
Device communication issue! This sometimes occurs fro many reasons mainly FIREWALLS~ In order to keep this from happeninig you should probably setup a static address on your laptop or if your network has a SSID, it needs to be manually set into your adapter because it is not picking up your network. This often happens when you use your laptop in or on other networks. Easy fix, but need answers to these questions!
Nov 25, 2007 | SMC Barricade g SMC2804WBR Wireless Router
Smc 2632w drivers for use on a tosiba a-105-s1014
go to this link and download it and save it in the desktop>and double click on that automatically it will install follow the instrucyion >thx
rate me solved if its helps
Oct 25, 2007 | SMC EZ Card network Adapter
Computers & Internet Logo
David Payne
David Payne
